How To Root MTK6589 Tutorial
- This topic has 119 replies, 111 voices, and was last updated 12 years, 3 months ago by
Marios.
May 2, 2013 at 10:16 AM #3792
MemberThis procedure should work with most of the recent MTK6589 phones. It is based on the motochopper exploit. If it works for you, please post your device make and model here.
First, you must install USB driver for your phone if not already installed. A guide on how to install USB drivers and driver files can be found here:
How to install MT/MTK 65xx USB driver on Windows 7When the Android driver is properly installed, the Device Manager dialog on your computer should look like this when your Android phone connected:
[ATTACHMENT NOT FOUND]Steps:
- Dowload the attached rooting package
[ATTACHMENT NOT FOUND] - Extract contents of rooting package into a folder
- Enable usb debugging on your phone from Settings > Developer options
- Open extracted rooting package in Windows Explorer and right click on the folder name while pressing shift button and select “Open command window here”. Alternatively, you can double click the run.bat in Windows Explorer window.
[ATTACHMENT NOT FOUND] - Type run or run.bat to run the batch file
[ATTACHMENT NOT FOUND] - Press enter
- Connect your phone if not already connected
- Batch script will push the exploit into your phone and install superuser.
- When the process completes, press enter and reboot the phone.
May 9, 2013 at 12:53 PM #13158gmozen
Participantmy phone is guophone G9589 MTK6589. root posible or not
May 9, 2013 at 1:12 PM #13159imported_umit
Membergmozen wrote:my phone is guophone G9589 MTK6589. root posible or notI don’t know. It should work for most of the MTK6589 phones. You can try and let us know the result if you wish.
May 9, 2013 at 4:09 PM #13165gmozen
ParticipantThere isn`t Developer options in my phone.I have not install usb driver
[hr]
There are not Developer options in my phone.I have not install usb driverMay 9, 2013 at 5:23 PM #13167imported_umit
Membergmozen wrote:There isn`t Developer options in my phone.I have not install usb driver
[hr]
There are not Developer options in my phone.I have not install usb driverTry the Enable hidden developer options menu tutorial first. If not successful, you can still install the driver with this method. After that, you can install new ROM on your phone with SP flash tool, but I am not sure about rooting.
May 9, 2013 at 10:48 PM #13169bambou972
Participanthello,
This tuto work for my phone:
HDC GALAXY NOTE 2 N9589
thx a lot,
May 10, 2013 at 8:09 AM #13176Win Liow
MemberCan I root my THL W7+_ 6589 using this method?
Here is a pic of my phone:
http://www.thlmobilestore.com/thl-w7-android-4-2-quad-core-smart-phone-mtk6589-5-7-inch-hd-ips-screen-3g-gps-3-2mp-front-camera.htmlMay 15, 2013 at 9:12 PM #13229cuboide
ParticipantCubot A6589 rooted!!!
May 16, 2013 at 10:30 PM #13240danycmoi
Participanth7500+ rooted!!!
: Dtank you
May 17, 2013 at 6:30 PM #13241markkus1
MemberMy phone is isa A19Q MTK6589, Android 4.2.1. Root posible or not ?
May 20, 2013 at 4:58 PM #13250perpetualnoob
MemberWin Liow wrote:Can I root my THL W7+_ 6589 using this method?Here is a pic of my phone:
I won’t be much help, but I was wondering if you got your phone rooted already, I just bought a HTL W100 and I’m hoping this method works.
May 21, 2013 at 6:40 PM #13256macmelvyn
MemberZTE V987 Rooted quite perfectly, thank you so much /M
May 22, 2013 at 6:03 AM #13284droidchinaloh
ParticipantRooted Successfully!
Note:
For my android phone 4.2.1 as detailed below, I must press ‘Grant’ button’ on my phone after Step 8 for the rooting to continue.Phone Details:
Phone Brand: HDC Galaxy N9589
Model Number: v89_gq2008s
Android Version: 4.2.1
Kernel Version: 3.4.5
Build Version: v89_gq2008s_20130403May 29, 2013 at 7:46 AM #13361nicodemo76
Member: D star n9500 – ok! Grazie.
May 31, 2013 at 10:53 AM #13394pyratessss
Memberworked for s4 clone GT-H9500 THX VERY MUCH
