ZUK Z2 Passes TENAA, Features SD820 & 5-inch Display
  • #10781
    ZUK CEO Chang Chen had revealed a few days back that the company was going to release a new flagship in the month of May, which would be called as the ZUK Z2. A surprise feature of the new ZUK handset was expected to be the Samsung Exynos 8890 chipset inside. However, after seeing the first teaser for the upcoming handset, we were all disappointed. The teaser showed that the phone was going to come with a Snapdragon chip inside. Then, we speculated that there could be a version which runs on Exynos 8890. But that’s probably not going to happen, given that ZUK Z2 has just passed through the TENAA certification website and it basically confirms the presence of Snapdragon 820 on board.
    zuk z2 02
    Before we move on to the specs, let’s take a look at the design of the handset. Not much will be different than the ZUK Z2 Pro version, except for the screen size, which is now reduced to 5-inches, instead of 5.2-inch on the Pro and the camera placement at the back, which is now on the top left corner instead of the center.
    zuk z2 01
    As for the specs, the ZUK Z2 model will feature the Snapdragon 820 chip clocked at 2.15GHz with two memory variants, 3GB + 32GB and 4GB + 64GB. The display will be of 5-inches with 1080p resolution. At the back, the phone will have a 13MP sensor while up front, you will find an 8MP shooter. The battery is decent, with a capacity of 3500mAh. The phone seems to be running on Android 6.0.1 version out of the box and comes with 4G LTE and dual-SIM dual standby support.
    zuk z2 teaser
    There is no mention of Exynos 8890 anywhere on TENAA, and we wonder why CEO mentioned this chip while talking about this new device. Another important question will be, how many of the unique features of the ZUK Z2 Pro will be retained by this model, which is expected to be cheaper. It is said that the phone will start at 1799 Yuan ($274).
    ZUK Z2 will be officially unveiled on May 31. Stay tuned for details.
