ZTE VR Announced, Will Support Google’s Daydream Platform
  • #10794
    To complement the newly announced Axon 7 flagship, ZTE also announced a new VR device, called simply as the ZTE VR. Like expected, this will be just like the other VR headsets we have seen in the market that works with a smartphone.
    ZTE VR 01
    The company had revealed earlier that the Axon 7 was also was going to be a great device for VR, and this is basically why it decided to use a 2K screen on the flagship instead of just 1080p. Further, the phone’s advanced audio capability with dual speakers will be one of the biggest highlights of the VR experience with the new phone.
    The ZTE VR comes with built-in 9 axis gyro sensor and a lens with 38mm diameter and 96 degrees field of vision. It weighs about 255 grams. ZTE also reveals that it is one of the first companies to support Google’s Daydream platform for high-performance mobile VR with the new Axon 7 model.
    The ZTE VR is priced at 518 Yuan which comes to around $79.
    In fact you can check out the specs of the new VR device from down below. A few actual images of the headset are also added below.
    ZTE VR Specs:
    Dimensions 185.3×85.3×76.7mm
    Sensor functionality Built-in 9-axis gyro sensor
    Viewing adjustments Lens effect distance: 8mm
    Vision: 0-600 degrees
    Pupil Distance: Auto adaptive
    Lens Field of vision: 96 degrees
    Material: PMMA
    Diameter: 38 mm
    Parameter: Aspherical lens
    Material Body: PC + ABS
    Face mask: TPU + sponge
    Belt: Artificial leather + diving cloth
    Weight 255 grams (Only headset)
    IMG_1022 ZTE VR 02 IMG_1025 IMG_1028
