ZTE Q7 (iPhone 6 clone) receives TENAA networking license
  • #7597
    ZTE Q7
    Despite the fact that the iPhone 6 has received a lot of criticism over its design (it is probably the most criticized first generation phone in the last several years), this has not stopped some Chinese cellphones from copying it. Beside the Dakele 3 which was revealed yesterday, another “Chinese iPhone 6” has arrived.
    Today, a new phone from ZTE was discovered at TENAA. Its model number is ZTE Q7 and it received its network license on November 28. This phone (2G/3G/4G) has support for TD-LTE, LTE-FDD, WCDMA, TD-SCDMA, and GSM, as well as dual-SIM. Like for its Nubia series, ZTE also added a small round circle for this phone. Its overall design looks strikingly similar to the iPhone 6. Fortunately, it does not have a protruding camera.
    As for its specifications, this phone sports a 5.5-inch 720p display screen. It uses a 1.5GHz octa-core chipset (Snapdragon 615), has 2GB RAM, 16GB ROM, a 3mp front-facing camera, and an 8mp rear-facing camera. It also runs the Android 4.4.4 operating system.
    CPU
    1.5GHz
    RAM
    2GB
    OS
    Android 4.4.4
    WAP
    supported, Wap 2.0
    GPRS
    supported
    Camera
    supported, 3mp, 8mp
    # of cameras
    2
    Java
    not supported
    ROM
    16GB
    Local connectivity
    Bluetooth, USB
    handwriting recognition
    supported
    radio
    supported
    USSD
    supported
    POC (PTT)
    not supported
    WLAN
    supported
    streaming media
    not supported
    IMPS
    not supported
    SyncML
    supported
    Video
    3GP, MPEG-4, AVI
    Audio
    WAV, AMR, MP3, MID
    JPG, GIF, PNG, BMP
    EDGE
    supported
    electronic dictionary
    not supported
    PDA
    not supported
    GPS
    supported
    Optical zoom
    not supported
    Expanded memory
    supported, T-flash
    Expanded card maximum
    32GB
    3G
    not supported
    customization
    non-customized
    TV
    not supported
    TV OUT
    not supported
    FM transmitter (car)
    not supported
    Video phone
    not-supported
    Video recording
    supported, 1080p
    Sensor
    CMOS
    CPU cores
    8
    Email
    supported, POP3
    HDMI
    not supported
    Special features
    G-sensor, proximity sensor, light sensor
    Internet frequency
    900MHz, 1800MHz, 2GHz, Band 38, Band 39, Band 40, Band 41, 2500-2690 MHZ, Band 3, 1.9GHz, I
    Colors
    black, white
    Dimensions
    157 x 78 x 7.9 (mm)
    Weight
    160g
    Cellphone connectivity
    GSM, TD-SCDMA, TD-LTE, LTE FDD< WCDMA
    Display screen
    Resolution: 1280 x 720, Size: 5.5-in, TFT
    Antenna
    built-in
    ZTE Q7 ZTE Q7 ZTE Q7
