Zopo has not released its new smartphone for some time, when most manufacturers go after producing the Octa core android 4.4 smartphone which can support 4G LTE but we can think that the price will be high, while Zopo company will release ZOPO ZP320, a new model, which can also support 4G LTE, run Android4.4 kitkat OS, there is main difference that it has Quad core processor and it sells at the best price which you must afford. There is another uncertain factor about its exact availability date. On the other hand, it’s worthwhile to wait for its coming!
Check What you will get from it:
– MTK6582 Quad Core 1.3GHz
– 5.0 Inch 960 * 540 Pixel QHD IPS OGS Screen
– 1GB Ram 8GB Rom
– 8.0MP Rear Camera, 2.0MP Front Camera
– Support 4G LTE Network, WIFI, GPS, Bluetooth, Multilanguage, etc
– 2300mAh Battery
Above all, you will be satisfied with Android4.4 OS, and 4G LTE Network, about the screen resolution, how nice it would be if it were HD IPS screen with 1280*720pixel. On the contrary, it is another cheap slate of Zopo, the overall performance looks good! Quad core 4G LTE smartphone can also be the best competitor with quad core 3G WCDMA smartphones. Just check the details from 1949deal now!
