Zopo ZP100 review.
- This topic has 4 replies, 5 voices, and was last updated 12 years, 11 months ago by
arigbuy.
December 23, 2012 at 11:27 AM #3422
droidster
ParticipantFirst thing you notice when you actually hold the Zopo ZP100 in your hand is that, even though it has a 4.3 inch screen it fits quite nicely in your hand. It’s also on the thinner side, not as thin as I would have liked, but you shouldn’t have any problems controlling it with one thumb. Another pro is that like many new Chinese Android devices, it’s running Android 4.0 Ice Cream Sandwich. Two features I personally haven’t find much use for, but you might, are it’s dual sim capability and the ability to track five fingers simultaneously.
The Phone comes with a 1Ghz processor, which makes scrolling through screens, web browsing, gaming and video playback a pleasant undertaking. Let’s go on and have a more detailed look at these features shall we.
Without exaggerating too much I found that browsing the web on this phone is almost like flipping through it’s menu. Depending on your connection the pages load instantly with no waiting time. A pet peeve I tend to have with phones and tablets is a laggy pinch zoom, well rest assured this never happens with this phone. In fact it might run more smoothly than phones I tested which were 3 times the cost.
Games are usually the achiles heel of a phone, but to my suprise the ZP 100 has no issues with most of the games you’ll throw at it. Of course you’ll have some issues with with gpu intensive 3D games, but for the most part games should be smooth sailing.
As you’d expect, it handles videos flawlessly, no hiccups whatsoever and due to the high resolution (960 x 540) the image quality you get is superb.
The technical specs are as follows for the ZOPO ZP100:Operating System Android 4.0
Networking WCDMA,GSM
Data Transfer GPRS,HSPA,EDGE
SIM Slot 2
Wi-Fi Yes
GPS Yes
Processor MTK6575 1GHz
GPU PowerVR SGX531T
RAM 512MB
ROM 4GB
Available Memory 2.53GB
Memory Card Supports Micro SD
Screen Size 4.3 Inch
Touch Screen Capacitive
Resolution 960 x 540 Pixels
Colors 16M
Camera 5.0 MP
Auto Focus Yes
Video 720P
Touch Focus Yes
Secondary Camera Supported Yes
Secondary Camera Lens 300K Pixels
Bluetooth Support 2.1
I/O Interface Micro USB,3.5mm,SIM slot
FM Yes
TV No
Format Supported MP3/ACC/AMR/OGG/M4AMID
/WAV/3GP/3G2/MP4
Sensor G-sensor,proximity,compass
Battery Lithium 1650 mAh
Talk Time 300 Minutes
Standby Time 150 HoursOverall should you by this phone? Yes. It’s typically around 180$ but, if you do some searching you can probably find it for as low as 150 dollars. If you were to chose the same specs from a manufacturer like HTC or Samsung, you’d probably be paying double that.
October 23, 2013 at 7:48 AM #14766zhun1buy
MemberI am occasionally understands from an online store of this kind of mobile phone. Want to know more detail on the phone.
October 24, 2013 at 6:42 AM #14773snowhill
MemberThe configuration seems to be not so high, only 512MB RAM. MTK6575 chip, single core cpu.
I find another ZOPO phone: ZOPO ZP900S Leader Smartphone 5.3 Inch IPS Screen Android 4.0 MTK6577 dual core 4GB ROM GPS, only sold $159.99, seems to be more cost-effectiveOctober 26, 2013 at 8:59 AM #14789rellaz
MemberNice review! More photos and real user experience would be better though.
December 5, 2013 at 2:43 AM #15207arigbuy
ParticipantThe relation between quality and price is really good. The speakers and microphone works well, the camera is ok.
