ZOPO Unveils Speed 7, Speed 7 Plus & A Circular Z-Watch At MWCS 2015
  • #8753
    Apart from revealing its new spokesperson and strategy, the company also showed off the brand new ZOPO Speed 7 Plus and Speed 7 flagships at the event. Both look identical, expect for the size. Even the specs are more or less similar.
    speed7_7
    Both the phones come with MT6753 octa-core 64-bit chip with support for a lot of 4G bands along with 3GB RAM and 16GB of internal storage. This can be further expanded up to 64GB via MicroSD. There will be a 13.2MP rear camera at the back as well as a 5MP front facing shooter.
    speed7_9
    While these specs are similar, the major difference between the two handsets will be the screen size. The ZOPO Speed 7 Plus sports a 5.5-inch 1080p full HD display with 400 ppi pixel density, while the Speed 7 comes with a smaller 5-inch display and 1080p resolution. Also, the Speed 7 Plus has a larger 3000mAh battery as compared to Speed 7’s 2500mAh. Both come with dual SIM dual standby and support 4G LTE/ WCDMA/ GSM networks. Finally, these devices will run on Android 5.1 Lollipop OS.
    The company has paid special attention the body of these two devices. The front is a rectangular body with round edges, while at the back, you have a brushed metal like finish. The back reportedly went through CNC precision grinding along with multiple spray coats.
    speed7_1
    ZOPO also unveiled its first ever smartwatch, the ZOPO Z-Watch at the event. It will be a circular smartwatch with 360 degrees cambered surface 1.22″ touch screen. Some of the features of the smartwatch include, swiping to answer calls, checking text messages, remote music control, gesture wake, heart rate monitoring, sleep monitoring and even remote shooting via Bluetooth. Unfortunately, no ideas on the pricing for the Z-Watch yet.
    20150715101423_40483
    The Speed 7 and the Speed 7 Plus will be available for pre-sale from August 3 at a price tag of $199 and $299 respectively. However, you can get a $40 OFF coupon directly from the company in the promotional period. You can generate the coupon from here. The company is also conducting a ‘Get A Free Speed 7′ activity on Facebook. You can check out its details from their official Facebook page.
