Zopo Speed 7 Plus Review
- This topic has 0 replies, 1 voice, and was last updated 11 years, 1 month ago by
September 15, 2015 at 10:10 AM #9198
MemberWe wanted to say thank you for Comebuy.com for sending Zopo Speed 7 Plus for a review!
Zopo Speed 7 Plus Review: VIDEO
Zopo Speed 7 Plus Review: SPECS
Display
5.5″ 1080P (Full-HD)
Processor
MTK6753 64bit Octa-Core, 1.5GHz
RAM
3GB
Camera
5MP Front/13MP
Connectivity
Bluetooth, 3G, 4G, GPS, WIFI, GSM,EDGE, GPRS, UMTS, HSPA, HSPA+
Battery
3.000 mAh (removable)
Dimensions
14.6 x 7.1 x 0.85 cm / 5.74 x 2.79 x 0.33 inches / 170g
OS
Android 5.1
Storage
16GB (expandable via microSD card slot up to 64GB)
Zopo Speed 7 Plus Review: UNBOXING
The multimedia experience is good overall. The video playback is nice and smooth and the sound quality via earphones is decent.
However, the loudspeaker could be louder and the sound quality does not impress as it lacks depth and the sound is a bit muffled. Anyway, this is common to the majority of phones in this price range.
Zopo Speed 7 Plus Review: CAMERA
The phone has a stock Mediatek camera app with a few settings a shooting modes. However, there is one annoying bug that irritates me. Each time you want to enter the camera app, it shows the instructions how to use as the phone thinks you are opening the app for the first time.
Zopo Speed 7 Plus Review: IMAGE QUALITY
The daylight images produced by the Zopo Speed 7 Plus are actually pretty good. They have a good amount of details, colour reproduction is good but the dynamic range can be a hit or miss.
The pictures taken indoors look good when there is plenty of lighting but could be better in lower-light situations as there is less detail, a lot of noise and the shutter speed slows down.
The night pictures do not impress but some of the images look pretty good for a budget device.
Zopo Speed 7 Plus Review: VIDEO QUALITY
The 1080p video quality is far from the best but it looks okay for a budget phone. The level of details could be better but I liked the colour reproduction, auto-exposure and the fact that the footage does not look very shaky. See the video review for a video sample.
Zopo Speed 7 Plus Review: CONNECTIVITY
I don’t have any complaints about connectivity options as the call quality along with the signal reception are good, Bluetooth and wifi are also working fine. GPS is fast to get a position lock but it could be a tad more accurate and it is not on par with the phones, powered by Snapdragon chips.
Zopo Speed 7 Plus Review: BATTERY LIFE
The 3000mAh battery performs great. I could get from 3 to almost 5 hours of screen-on time depending on what I did with the phone. If you are gaming or taking lots of pictures every day, you may get a 3.5 hours of screen-on time.
Zopo Speed 7 Plus Review: CONCLUSIONS
So there you have, the Zopo Speed 7 Plus. The phone has a solid built quality but it lacks premium materials like metal in its design. The IPS display is bright, vivid and has decent colour reproduction.
As far as the software experience goes, it is snappy and performs well but the out-of-box bloatware is something that may be annoying. A good thing is that you can easily uninstall everything.
The performance is okay but it could be better as the occasional stutter does not ensure the best gaming experience.
Also, with the Zopo Speed 7 Plus you are getting a decent camera, good battery life and the 4G LTE support.
However, I believe that this phone is a bit overpriced as there are some other similar offerings, which have the same specs or even some extra features like a finger print scanner and a metal frame in its design, which cost $30 or even $50 less.
Overall, despite a few software bugs and some other disadvantages, the Zopo Speed 7 Plus is a decent phone. Is it worth the extra cash, it is up to you to decide.
Buy Zopo Speed 7 Plus with $11 off using the PROMO CODE: ZOPO77XHY
