ZOPO Speed 7 and 7 Plus Now Available for Pre-order at GearBest.com
  • #8816
    ZOPO’s upcoming Speed 7 and 7 Plus smartphones are now up for pre-sale over at GearBest.com until August 11, 2015. The ZOPO Speed 7 and 7 Plus are priced at $199.99 and $229.99, respectively, and while the Speed 7 will start shipping on August 25, 2015, the larger 7 Plus will start shipping earlier on August 18, 2015.
    gearbest-preorder-zopo-speed7-7plus-01The ZOPO Speed 7 and 7 Plus are pretty much the same device when it comes to their features and specifications. The only different between the two is their sizes and batteries. While the Speed 7 comes with a 5-inch display, a 2500mAh battery, and measures 14.61 x 7.06 x 0.865 cm the Speed 7 Plus comes with a larger 5.5-inch display, a larger 3000mAh battery and measures 14.6 x 7.1 x 0.85 cm. The Speed 7 Plus is also 50 grams heavier at 550 grams.
    gearbest-preorder-zopo-speed7-7plus-04Both smartphones feature 1080p full HD resolution IPS displays, a MediaTek MTK6753 64-bit 1.5GHz octa-core processor, a Mali-T720 FPU, 3GB of RAM, 16GB of internal storage, and support expandable storage via microSD card up to 64GB. Both are also equipped with 13.2-megapixel rear cameras with LED flash, 5-megapixel front-facing cameras, dual SIM dual standby support, and come with Android 5.1 Lollipop. Both also feature 4G LTE connectivity as well as Wi-Fi 802.11n, Bluetooth 4.0, and GPS.
    Both the Speed 7 and 7 Plus are available in either white or black and, as previously mentioned, can already be pre-ordered through GearBest.com for a price of $229.99 for the Speed 7 Plus and $199.99 for the Speed 7.
    BUY ZOPO Speed 7
    BUY ZOPO Speed 7 Plus
    gearbest-preorder-zopo-speed7-7plus-02 gearbest-preorder-zopo-speed7-7plus-03
