ZOPO C3 focus on women featured smartphones
  • #4113
    ZOPO mobile phones this year, not only helping to create a joint aliyun popular quad-core products ZOPO C2, a few days ago also came ZOPO will cooperate with Jingdong, or for creating a new generation of depth custom machine, and recently appeared ZOPO C3 that is likely to become the ideal choice However, the two sides have yet to publicly answer, the end result may be announced July 8.
    ZOPO C3 has opened its first official store purchase of 999 yuan, and the price is very cheap at only 999 yuan, the information from the official release of the next batch of shows ZOPO C3 Offer may be arranged in the July 8, combined with aspects before ZOPO remarks can guess on July 8 will probably C3 custom machine identity stationed Jingdong, Jingdong Mall by the exclusive sales, but does not rule out other mobile products, in Jingdong sale, the same can be synchronized with other sales channels, the overall the former possibility is higher.
    ZOPO C3 debut as the female mobile phone with 8.5 mm slim and ultra-narrow frame, and another white, pink and blue and other variety of dazzling colors, although the gap size measurements and black little, but back curvature of the design even more softer, as well as Le frog is ZOPO ZP980 customized system, in the female users are more concerned about interface themes, applications, etc. are more female characteristics.
    Core configuration ZOPO C3 is equipped with the MT6589T 1.5GHz quad-core processor, with a 5-inch IPS screen all fit, 1080P display resolution, surface and anti-scratch resistant Corning Gorilla Glass. Terms of memory use 1G RAM +16 G ROM combination, maximum support 64G expansion. And equipped with front 5.0MP +13.0 MP back-illuminated CMOS (blue glass filter) dual high-definition cameras, standard 2000 mA battery, can support WCMDA + GSM dual network.
