Xiaomi Redmi Pro Official With 13MP Dual Cameras & Helio X25
- This topic has 0 replies, 1 voice, and was last updated 10 years, 2 months ago by
July 28, 2016 at 10:10 AM #11323
MemberAfter months of leaks, rumors and teasers, Xiaomi has officially unveiled the Xiaomi Redmi Pro flagship. Like the name suggests, this will be the most powerful Redmi device from the company till date, featuring top-end specs that will rival existing flagship smartphones in the market. The Redmi Pro, like expected, comes with dual cameras at the back, a first for Xiaomi and hopefully something that will continue in upcoming devices.
Like we saw in the leaked images, the Redmi Pro will come with an all metal body with CNC diamond cut and brushed metal finish with gloss anodizing process. This will ensure that the phone looks like a true flagship, featuring premium and refined design. You get USB Type-C port as well as 3.5mm headphone jack on the device, along with a 5.5-inch display and 2.5D glass up front. The fingerprint sensor is located on the front of the phone, embedded into the home button. As for the measurements, they are as follows: 151.5 x 76 x 8.15mm. Considering the phone features a large 4050mAh battery, this is pretty good.
Now, coming to the most important part i.e. the specs. As we saw in the TENAA listing a couple of hours back, the Xiaomi Redmi Pro will come in three variants. The low-end version runs on the deca-core Helio X20 with 3GB RAM and 32GB of internal storage. Then there are two Helio X25 powered models that come in the following variants: 3GB RAM + 64GB ROM and 4GB RAM + 128GB ROM.
For the first time, Xiaomi has used an OLED panel on the device and the company claims its way better than the traditional LCD panels. The phone is using a 5.5-inch FHD OLED panel. It boasts of 100% NTSC color gamut. The company has also released a couple of images to compare the difference between the two technologies.
Now, moving on to the camera department, the Redmi Pro comes with dual cameras at the back. The primary camera will be a 13MP Sony IMX258 sensor and the secondary sensor will be a 5MP Samsung one. The aperture value ranges from f/.095 to f/5.6. The company claims that the use of dual camera setup helps the phone take real time hardware level bokeh images. The resulting images are said to be comparable to the ones taken from a DSLR camera. The presence of the ImagiQ Pro chip also helps to improve this function. Further, you can reportedly adjust the focus after the image is captured.
Up front, the phone comes with 85-degree wide-angle 5MP sensor.
As for the battery, its large and will easily last you a couple of days. You get a 4050mAh battery inside, like the other Redmi models in the lineup, which will make sure that battery life isn’t going to be an issue on this particular phone. There are other standard connectivity features such as VoLTE, Wi-Fi, Bluetooth, 4G+ etc.
The Xiaomi Redmi Pro goes on sale on August 6, both offline and online. The base variant with Helio X20 + 3GB RAM + 32GB storage starts at 1499 Yuan ($224). The Helio X25 model with 3GB + 64GB will retail at 1699 Yuan ($254) while the Helio X25 + 4GB + 128GB model will retail at 1999 Yuan ($300).
The top end model enters the territory of Snapdragon 820 flagships like Mi5 and ZUK Z2! So, we hope that the new Redmi Pro comes with an amazing camera!
What do you think about the new Redmi Pro?
