Xiaomi is known for producing cost-effective products. On November 11, they will release the Xiaomi Power Bank 16000mAh version and it will cost just 99 RMB (16.17 USD). Here is an unboxing of Xiaomi’s foray into the mobile battery industry.
The Xiaomi Power Bank comes in a white box. The front side of the box has nothing on it except the Xiaomi logo at the bottom.
On the left side of the box are barcode labels and anti-fake stickers.
On the right side of the box are the specifications of the power bank.
Besides the power bank itself, the package includes the manual and a USB cable.
The Xiaomi power bank 16000mAh version uses an aluminum case.
The body is covered with a sticker used to protect the power bank. Same goes with the USB ports.
The 16000mAh version has two USB ports, which allows the user to charge two phones at the same time. It only comes with one wire.
The 16000mAh version is slimmer than the 10400mAh version.
Not surprisingly, the 16000mAh version should last much longer than the 10400mAh version.
