A couple of days back, Xiaomi announced its Xiaomi Mi4C mid-range flagship for a competitive price tag of 1299 Yuan ($203). The phone comes with top-notch specifications, especially for a device in its segment.
There’s the hexa-core Snapdragon 808 chipset under the hood along with 2GB / 3GB RAM and 16GB / 32GB storage options. The display up front is of 5-inches with FHD 1080p resolution. The rear camera is a 13MP Sony IMX 258 sensor with improved algorithm for better low light images (brighter and less noise). Up front, there’s a 5MP shooter with wide angle lens for the perfect group selfie. The phone comes with 3080mAh battery with Quick Charge 2.0 and a USB Type-C port. There’s even an IR port up on top.
Overall a great device in terms of specifications for just $203. But is it durable enough? Well, folks from China just did a drop test of the new Mi4C and in general, the phone did quite well.
In the waist high drop test, from around 1m high, the Mi4C survived the fall. No visible scratches or damages. Even in the second drop test from chest height, (around 1.5m), the phone survived as well. This shows that the display is quite strong and can definitely withstand a few falls.
However, in the third drop test, which was from over the head height, the Xiaomi Mi4C didn’t survive. That’s like the worst case scenario and its unlikely that you would drop your phone from such a height. So, in most cases, the Mi4C’s 5-inch display should survive a fall.
Anyways, take a look at the video and see it for yourself.
