What’s the cheapest way to buy Mstar M1 Pro
- This topic has 0 replies, 1 voice, and was last updated 11 years, 3 months ago by .
The midrange smartphone market is complicated at times. Until recently have quad cores phone was all a guaranteed success in performance, I do not say anything if you had 1GB of RAM or 5 “screen. Everything evolves and makes it very fast and this is where the new Mstar M1 Pro, a worthy successor to Mstar S700 that recently had occasion to see right here goes.
The new Mstar M1 Pro incorporates a great Octacore CPU , the MT6752 to 28nm 1.7GHz 64bit with 2GB of RAM and16GB of ROM (expandable via microSD cards up to 64GB) along with Mali T760 GPU. The performance of both is extraordinary in terms of multitasking and graphical ejecucacion of 3D titles.
Mstar Pro M1 is using IPS OGS with a 5.5 “ screen and a maximum resolution HD 1280 x 720 pixels . A panel of high resolution and low power consumption, with an acceptable level of brightness and saturation that does not tend to yellow as others we’ve seen before.
The resolution is standard for this type of devices midrange and allow us to play thanks to the support of the GPU to almost any type of game without noticing any lag on the screen.
The Mstar M1 Pro stands out for its metallic bezel made by alloy of aluminum and zinc certainly make it felt more durable in hand, highlighting over others who just opt for polycarbonate in all parts.
As you can see, there are many similarities in his brother S700 both in terms of processing and performance. We are facing a terminal that incorporates a rear camera 13MPx with autofocus and LED flash and a front of 8Mpx . The photographic section is well covered through the stock camera app that has some interesting shooting modes as trim, panoramic, automatic and manual functions that allow us to balance the white and change the ISO default level. The front camera has 8Mpx with so performance is assured when making selfies of yourself.
In addition, the new Mstar M1 Pro is Dual-SIM and has conectitividad GPS, A-GPS, Wi-Fi N, Dual SIM, Bluetooth and FM Radio . Obviously, the new M1 Pro MStar has conectitividad 4G LTE fully operational with the Spanish bands that do not have any problem when using it.
Battery 3000mAh , Android 5.0 Lollipop and gesture recognition system on screen and unlocking active through double tap complete the features of the new MStar M1 Pro which has a maximum weight of 126 grams.
