What is the cheapest way to buy No.1 Mi4?
- This topic has 0 replies, 1 voice, and was last updated 11 years, 10 months ago by .
We have seen plenty of clones in the market of Xiaomi’s latest flagship, Xiaomi Mi4. Of these, the No.1 Mi4 and the Doogee DG850 Hitman were the two popular ones. Both come with the same features and design, however, there are some differences between the two, which gives the No.1 Mi4 a slight edge over the other. You can check out our detailed comparison between the two devices here. Given that they both look the same and are similar in tech specs, we decided to figure out the cheapest way to buy the No.1 Mi4 smartphone.
Before we reveal the cheapest way to buy the No.1 Mi4 smartphone, lets recap on its specs. The device is powered by a decent Mediatek MT6582 quad-core processor clocked at 1.3GHz with 1GB RAM onboard. For GPU you have the Mali-400MP and for storage you have 16GB expandable memory. There is a 5-inch display up front with a resolution of 1280 x 720 pixels, which is a standard among phones in this price range.
Performance wise, the phone did pretty well. Playing games and running apps on the device was smooth. In our AnTuTu test results, it got a respectable score of 19000+. As for the camera, there is a 13MP shooter at the back with LED flash. It captured decent pictures in bright sunlight and we were pretty much satisfied with the performance. You can read our full review of the device for more details. The No.1 Mi4 runs on Android 4.4 KitKat OS with an MIUI launcher on top. This makes the phone look exactly like the original Xiaomi flagship Mi4. The notifications panel, settings menu etc are all customized to MIUI’s looks.
As you can see, the No.1 Mi4 turns out to be a great smartphone. And with the special coupon from GizmoChina, you can get it for the cheapest price from GearBest.
The No.1 Mi4 usually retails for around $165+. On GearBest you can get it for around $160. However, thanks to our coupon, you get around $20 off this price. We have personally tried out the coupon and it works perfectly, at least for now.
As you can see, before coupon, the phone is available for $161.13. However, look at the price after we have applied GizmoChina’s coupon.
Yes, you can purchase the No.1 Mi4 for just $140 with the coupon NO1MI4CN. That’s the cheapest price that you’ll find the phone online. We don’t know when this coupon will expire but make sure you take advantage of it as soon as possible.
Buy No.1 Mi4 for just $139.99 with coupon:NO1MI4CN
Over the next few days, we’ll bring you more such exclusive deals. So, stay tuned to the website!
