Vkworld T1 was unveiled back in May this year and the smartphone was famous for its super cheap aluminium unibody design. Now the brand has unveiled the successor to this device that goes by the name Vkworld T1 Plus. Vkworld T1 Plus comes with major improvements over its predecessor and this device is most likely to hit the shelves this month.
Vkworld T1 Plus features a 6-inch 2.5D curved glass LTPS SHARP display. The display is further equipped with Corning Gorilla Glass 4 protection and oleophobic coating. It sports 178-degree wide viewing angles. This smartphone sports 83% screen-to-body ratio as compared to 80% on Vkworld T1.
As far as the design of this smartphone is concerned, Vkworld T1 Plus features a full metal unibody design making use of 7000 aluminum alloy. Vkworld employed CNC and diamond cutting process to give this smartphone a curved back and it is available in multiple color options as well.
Read More: Vkworld Crown V8: Super Thin Budget Phone With Great Design Up for pre-order
In addition to that, the Vkworld T1 Plus houses a fingerprint sensor on the back for added security and is fueled by a 4500mAh battery. Rest of the features of this smartphone are the same as that on the Vkworld T1.
