Vernee is leaving no stone unturned in promoting its smartphone Apollo Lite. Now the brand has released some new images comparing the Spca Grey version of Apollo Lite with Meizu Pro 6 and OnePlus 2 in terms of its design and looks. So now let us go through this comparison to determine how Apollo Lite is different from the above-mentioned two smartphones from renowned brands, Meizu and OnePlus.
Apollo Lite is manufactured using an alloy of Zinc and Titanium. This smartphone sports a unibody design and the Zi-Ti alloy lends it durability and strength to the frame. In addition to that, this alloy gives it much-desired resistance against corrosion caused due to sweat and rain.
Apollo Lite is quite a looker in Space Grey colour and it is resistant to fingerprints, thanks to the 3D polishing and anodising. As far as looks are concerned you will find this smartphone quite attractive.
Vernee has used a high-quality material in the manufacturing of Apollo Lite and in addition to that you will notice expert never-fading craftsmanship in the process. Apollo Lite flaunts a classic rectangle design and you will see the perfectly rounded corners. The dual-C chamfering gives this phone the looks.
Apollo Lite features a slightly bent or curved frame which helps this smartphone to fit perfectly in the hands. Vernee has used 30-degree CNC high-gloss cutting on this phone which gives this smartphone the shining sides and improves the looks of Apollo Lite.
For the protection of the display, Vernee has used Corning Gorilla Glass 3 on Apollo Lite along with 2.5D curved glass to protect the display in case of accidental falls. Despite all the protection the display of Apollo Lite looks quite thinner and it adds to the beauty of this smartphone.
Read More: Tomtop Vernee Thor And Apollo Lite Flash SaleĀ
Vernee has also made it official that it will ship Apollo Lite to resellers on July 10 and the customers who have purchased the smartphone in pre-sale period will soon get the device. That being said Vernee is also holding a special campaign where users can get this smartphone for as low as $199. You can check more details of the campaign here.
