More and more manufacturers have adopted the full metal body design for their devices. One of them is Vernee that has created excellent built devices. Apollo Lite sports Zn-Ti alloy uni-body which features enhanced abradability and high resistance to corrosion of sweat and rain. Moreover, the 3D polishing and anodizing process that Vernee adopts endow it with great handling experience, anti-fingerprint feature and a beautiful look.
Besides the high quality material of the body, Vernee Apollo Lite, as well as Meizu Pro 6 and OP2, shows a never-fading craftsmanship on the process. The classic rectangle design with rounded corners and dual-C chamfering makes Apollo Lite look beautiful from every angle. The rounded corners and arc frame of Apollo helps the device fit in your palm pretty well. To improve the handling experience even further, Vernee uses accurate 30°CNC high-gloss cutting.
The device comes with a 2.5D Corning Gorilla Glass 3 screen that blends with the metal in a way that produces a beautiful design. In the photos, you can see the Apollo Lite next to two other beautiful devices. The Meizu Pro 6 and OP2 are also very well designed, therefore it adds credits to Apollo Lite. After all, so much good design and build-quality at such a price, is not something you see everyday.
You can order it now from Gearbest and take advantage of the $30 discount.
