Unbrick clone S4…
- This topic has 14 replies, 13 voices, and was last updated 12 years, 6 months ago by
[email protected].
September 5, 2013 at 4:27 PM #4467
r3d0x
MemberHi..
I’m a french who bought a china phone on dhgate.com.
This worked pretty well, except it fast heat at the Samsung logo.
I saw that AC had the rom and I wanted to flash a new ROM.
I put scatter.txt and I put dowload, except it did not work so I put firmware Uptdate. The loading is done. Since the phone is bricked. I can not turn, no sound using 10 seconds of power + vol (-). Nothing works.I test at least 20 Rom, I’ve looked everywhere, I tried to flash with SP and SP Flash tool MDT.
I could not know what to do, could you help me? I searched all the net …
Here is the link with the phone features:
(dhgate.com/product/smarphone-s4-i9500-n9500-unlocked-sim-free/165033648.html#ctabBox)With SP Flash tool , i have the error : “BROM ERROR : S_FT_ENABLE_DRAM_FAIL (4032) |[EMI] Enable DRAM Failed! “
Thank you in advance and I hope to use my new phone … :'(Contact by : Forum , MP , skype : x-r3d0x-x
My last info , when the phone worked :
Hardware : MT6589
GT-i9500
Version band base : i9500XXUAMDK
Build Number : JDQ39.i9500XXUAMDK
Core : 3.4.5-526212 se.infra@SEP-111 #1 Tue Apr 23 23:00:57 KST 2013September 18, 2013 at 7:26 AM #14406hamskies
ParticipantI think we have the same problem, I flashed a wrong rom using sp flash tool. now my unit is bricked, I need help, My computer cant even recognize the phone when i plug it in. how can I reset the phone or flash another rom.
September 19, 2013 at 3:32 PM #14450hamskies
Participantany luck on your side? I cannot find the proper rom to flash, if you find one please post it here. thanks.
September 26, 2013 at 5:28 PM #14491Danny-C.alfa
ParticipantSame problem.
Any ideas?
October 18, 2013 at 3:46 PM #14690rumo74
Membersame problem!! anything new??
October 21, 2013 at 9:22 PM #14735Bilout Sys
Participanthave you find ? thank for answer i have the same probleme my phone is freeze….:@
October 22, 2013 at 6:14 AM #14742imported_umit
MemberIf it is still flashable using recovery or SP flash tool, you need to find a suitable ROM for your device and flash. If it is not flashable, you have to try hardware recovery methods.
October 28, 2013 at 6:15 PM #14799Bilout Sys
Participantumit wrote:If it is still flashable using recovery or SP flash tool, you need to find a suitable ROM for your device and flash. If it is not flashable, you have to try hardware recovery methods.how it’s done for material recovery?, I ask the seller I telechatger the original release when he sells it, but I have this error “enable dram failed”
November 2, 2013 at 5:50 PM #148252005LINSAY
Participanti have also bricked my s4 clone not happy
November 6, 2013 at 9:38 PM #14849rajendrakumar
Memberhi friends,
i have clone samsung i 9500. problem is only shows blue screen.anyone please upload 4.2.2 rom for that mobile.cpu mtk 6575.November 7, 2013 at 5:01 AM #14855kformaran
Memberyou should backup first, before you flash a new rom
November 14, 2013 at 9:31 PM #14938psild
Memberkformaran wrote:you should backup first, before you flash a new rom
I have a Doogee Collo DG100.
I have tried to flash a new ROM but at the middle of the process I got an error from SP Flash Tool “BROM ERROR:S_NOT_ENOUGH_STORAGE_SPACE(1011)”. Now the phone does not start.
Can you please tell me what to do?January 11, 2014 at 1:55 AM #15660Toaha Imran
MemberEasy fix, but make sure you have another exact phone. I recovered mine with scatter file when preloader was corrupt.
March 4, 2014 at 7:41 AM #16092JAGAAN
MemberIam Having GT-I9500 Samsung S4 Copy Phone It showing Internal Storage of 2.46GB & Phone Storage of 10.45GB, but when i connect to usb mass storage mode, its showing 2.46GB only i cant use or transfer files to 10.45GB, pls help
March 30, 2014 at 5:50 AM #16397[email protected]
MemberToaha Imran wrote:Easy fix, but make sure you have another exact phone. I recovered mine with scatter file when preloader was corrupt.How did u do that… I have my original rom backup and preloader… but dont know how to flash it in this situation… please tell me bro.. Im very unhappy…
