Unboxing of Xiaomi Mi Robot Vacuum Cleaner
  • #11745
    After reading about the official launch of Xiaomi’s Mi Robot Vacuum, we knew you’d be itching for some real images of the product.
    The vacuum cleaner comes in white with the LDS sensors on the  top coated orange. Underneath the exterior is a NIDEC motor, an adjustable main brush and a plethora of sensors which includes a Laser Distance Sensor, a gyroscope, and a cliff sensor.
    The in-built 5200mAh battery will suffice for a 250 square metre area or 2.5 hrs of cleaning time.
    Xiaomi has put in 3 chips from Texas Instruments, Allwinner, and STMicroelectronics for processing of data.
    Using the Mi Home App, you will be able to plan cleaning paths, and schedules, and monitor the cleaning process and stats of the vacuum cleaner. There is also an additional virtual wall similar to what iRobot offers. The Mi Robot Vacuum has a MRRP of $254 and the virtual wall sells for $6.
    Below are the unboxing images. I like how the charging cable folds neatly behind the charging dock. Quite neat.
    20160831_153739_45920160831_153741_27220160831_153743_610
    20160831_153743_5
    20160831_153755_84120160831_153753_9720160831_153753_79920160831_153747_71320160831_153755_25420160831_153739_98820160831_153747_172
    20160831_153744_10420160831_153744_74820160831_153745_35020160831_153748_28520160831_153741_90820160831_153740_55820160831_153751_82120160831_153745_945
