UMI X3 leaked with more hardware details
  • #5262
    jasonli
    As same as UMI X2,UMI X3 will also launch two version,it is 3G(WCMDA+TD-CDMA) and 4G Lte version,the 3G version will on sale first and UMI X3 3G version hardwares are unveiled.
    It is said that UMI X3 only has 7.2mm body and 3150Mah battery,if this is true it is really exceting.Besides the thin body, UMI X3 3G version will have a 5.5-inch FHD display with Corning Gorilla Glass, 14 mega-pixel main camera/8.0M pixel front camera, 3G support, 2GB RAM and all the usual flagship features from a NFC to WIFI, GPS, Bluetooth and more.
    The 4G LTE version also leaked some informations,it is purported that X3 will support TD-LTE/FDD-LTE/TD-SCDMA/WCDMA/GSM network,the processor will also use MTK6592 4G LTE Chip,and the hardware may update to 3G RAM and 16.0M pixel rear camera.
    etkchina
