Umi Iron Pro – World’s Most Secure Smartphone
- This topic has 0 replies, 1 voice, and was last updated 10 years, 11 months ago by
smartphone mania.
November 6, 2015 at 3:42 AM #9540
smartphone mania
ParticipantUmi Iron Pro now has a Flash Deal activity at 1949deal.com, and it begins from 7:00 AM Nov 9th to 14th(EDT). During the promotion, the device only sells $149.99 USD but limits 100 pcs only. But if you miss it, don’t worry, we have plan B. During Nov 4th to 14th(EDT), Umi Iron Pro sells $179.99, including one tempered glass protector and one flip cover. As to why you need to buy this device, now I will tell you in details.
[img]http://www.chinaphonearena.com/forum/attachment.php?aid=2676[/img]
UMi Iron Pro physically looks similar to the UMi Iron but it gets a single piece rear panel. The UMi Iron has a metal main body with plastic at the bottom and top, while UMi Iron pro has a single piece. And the UMi Iron Pro will have USB Type-C, a fingerprint scanner on its rear side, and eye-scanner running on the front camera. The display specifications are the same as the first model. The device measures 5.5 inches with 1920 x 1080 display. The LED notification bar at the bottom is retained.The most important thing about the phones must be its processor. Umi Iron Pro is definitely generous in placing impressive hardware by running a MediaTek MT6753 chipset with an octa-core Cortex-A53 processor clocked at 1.3GHz and Android Lollipop 5.1 system. Its memory storage is good enough with carrying 3GB of RAM and 16 GB of ROM.
As the title mentioned, Umi Iron Pro is the most secure smartphone in the world you can get, and it is the very first smartphone to be running three security features. The first one is a fingerprint scanner present at the rear side, and apart from this, there is also an iris scanner and a voice recognition feature. Umi Iron Pro makes sure that your private life remains just that: private. It’s the first smartphone to feather both fingerprint scanner and eye scanner technology. The eye scanner data registered on your UMi Iron Pro is encrypted and stored safely, which means that no third party can ever access your files. Any apps that contain sensitive information can also be locked and opened via the fingerprint sensor or by authorized users with visitor mode.Another highlight of this device is it utilizes the new USB Type-C standard so that the users can be easier to transfer the files. The rear camera is Sony IMX214 13MP while the front one is 8MP along with F/2.2 aperture and a front face Led flash, which makes your selfie better than ever before.
The LED notification light is not your common one. It’s Skyline Notification, an aesthetically pleasing oscillating light that can ensure you never miss the important message. You can customize the colors of red, blue and green. The device also features your health problem by supporting heart rate, blood sugar, cholestrol level, calories burnt and even stress index measure functions.
When you want to show off your phone to friends without sharing your secret like messages, files, photos, you are lucky enough to have this device by setting the Guest Mode, which allows you to present the phone normal to your friends to make your private remain intact.
UMi Iron Pro equips with advanced noise reducing headphone amplifier, making listening more enjoyable. Moreover, it supports full-network connectivity, keeping your life fully connected wherever you are.UMi Iron Pro has many advantages that you can’t find them all in a smartphone but only sells below $200 USD, if you are supposed to change a new ‘buddy’ then you have better consider this one.
