UMi Introduces the DG Twin-Shield Technology
  • #11130
    The major problem with the smartphones of today is the sub-standard display protection. The display on a phone is subjected to round the clock torture as we keep tapping on the displays all the time. Smartphones tend to slip and fall all the time and display is the first thing that gets damaged in case of a fall or any similar situation. Umi is continuously outdoing major affordable smartphone brands from past couple of months in terms of design and features it is providing on its smartphones and that too without burning holes in pockets. Umi has introduced a new display protection technology that is known as DG Twin Sheild Technology.
    umi london
    DG Twin Sheild Technology is the combination of 3M™ Double Coated Foam Tape and custom made dual 2.5D glass. This technology offers the best of both worlds as it combines beautiful design and next generation drop resistance. Umi is going to use this display protection technology on the upcoming smartphone, Umi London. Umi is touting this smartphone as the toughest dual protection smartphone.
    umi london
    Umi DG Twin Sheild Technology offers a 1.5M drop resistance which simply means that you do not have to worry about the shattering of display in case you phone falls from a height of 1ft. It comes as a major relief for those who have a tendency of occasionally dropping their phones.
    Read More: The Beautiful & Rugged Umi London Available From June 27
    If you are planning to buy Umi London then you can check out more details about this smartphone from here. Umi has also designed a custom rugged armor protection case for Umi London which you can check out at this link.
