UMI EMAX Is An Octa-Core 5.5-inch Phablet With A Massive 3780mAh Battery
  • #8353
    If you are looking for a smartphone which is powerful, affordable and long lasting, then you better check out the new offering from UMI. The UMI EMAX is finally available to pre-order from Geekbuying and one of the highlights of the device is its massive 3780mAh battery. The EMAX directly competes with the popular Meizu M1 Note, however, its much easier and even cheaper to buy the EMAX right now. Moreover, the phone manages to best the M1 Note with such a large battery.
    UMI EMAX
    However, battery isn’t the only highlight of the device. UMI EMAX comes with the powerful 64-bit MT6752 octa-core processor which easily scores above 40K on AnTuTu. The chipset has been increasing used in mid-range flagships, and offers great performance to price ratio. Along with this chip, you get 2GB RAM on board and 16GB ROM to handle your apps and media. The storage is further expandable up to 32GB via MicroSD.
    UMI EMAx 02
    Like the M1 Note, the UMI EMax comes with a 5.5-inch Full HD display. At the back, you will find a 13MP Camera with flash and AF and up front, there is a 5MP shooter. The phone naturally supports 4G LTE networks and the supported bands are as follows: 4G: FDD-LTE 800/1800/2600MHz.
    UMI EMAX 04
    Overall, the UMI EMax comes out as a powerful smartphone at just $170 price tag. Yes, the phone is being offered under $170 which is a great price for the specs that it offers. Its currently available for pre-order on Geekbuying. You can check out more details from the link below.
    CHECK OUT UMI EMAX PRICED AT JUST $170
    UMI EMAX 03
