Lots of Chinese smartphone manufacturers are integrating large battery capacities in their handsets and Ulefone Power, the newly announced smartphone from the company happens to be one of those devices that has joined that illustrious club.
As the name suggests, the newly announced device comes with two primary perks of owning it; a 6,050mAh battery and an extremely affordable price tag (given below). The battery is a Sony non-removable lithium polymer one and according to the company, users will be able to rake out a total of four days of light use on a single charge.
Bundled with Ulefone Power is a 9V/2-3A charger that makes use of Pump Express Plus technology; Qualcomm’s Quick Charge’s latest competitor that will super charge the smartphone’s battery in just two hours and allow users to gain a total of 2 hours of call time after being plugged in for just 5 minutes. Despite featuring such a large battery, Ulefone Power measures only 9.5mm in thickness and weighs in at 190 grams.
The smartphone also does very well to put on a good impression since it has a 2.5D arc display that is reinforced with Corning Gorilla 3 glass, and features a solid metal frame, along with ‘halo’ touch buttons. Ulefone has stated that there will be a total of three colors to choose from, which are as follows:
White
Dark blue
White with a wooden back cover
A SIM card tray pops out that can accommodate either one of the following configurations:
Single SIM card with a microSD card
Dual SIM cards
In addition to possessing a large battery capacity, Ulefone Power is no slouch when it comes to performance because it features MediaTek’s MT6753 SoC, 3GB of RAM, and a very powerful Sony IMX214 13MP camera with a dual LED flash. As for its screen size, Power has a 5.5-inch AUO 1080P LTPS display.
The handset also caters to the security eccentric crowd thanks to a fingerprint scanner and it will be getting an Android 6.0 OS update in the future. So when exactly can you get your hands on Ulefone Power? The company has stated that the smartphone will start to ship from January 10, 2016 with Android 5.1 pre-installed and will come with a very affordable price tag of $209.99.
In February, the handset will receive an update to Android 6.0.
