Yesterday we told you about the free tempered glass and silicon case that UHANS is giving away with every UHANS S1 device that you buy. The S Series is designed to be a “beauty outside and a monster inside” according to the company and that is not too far away from the truth.
It features a slim and sleek design with 2.5D curved glass panels on the front and rear of the device coupled with a metal frame and it only measures 6.8mm thick or 4.9mm at its thinnest points. The S1 is powered by a MediaTek MT6753 processor as well as 3GB of RAM and is equipped with a 13-megapixel rear camera, a 5-megapixel front-facing camera, and a multi-functional fingerprint sensor that is mounted on the rear of the device. It runs on Android 6.0.
The company decided to give it a boost so it is now available at a 50% discount until tomorrow and you can find it here for only $139.89 which is great for a MTK6753 device.
