ThL w11 monkey king is the best with a 2000mAh Battery
  • #4963
    mingtian00
    The face of the emerging wave of camera phones , ThL w11 monkey king phone also heavy attack, launched a ThL w11 Monkey King with a comprehensive configuration , outstanding highlights, ThL Monkey biggest highlight is the use of a stunning 13000000 pixel front camera. 5 inches Full HD screen , 2GB RAM, supports W / G network mode dual standby , rear camera is also a 13 million -pixel , using the built-in battery design , not removable .
    ThL Monkey King of the box is full of the Chinese traditional cultural elements , printed with the image of a big box like Peking Opera , ThL Monkey King uses a 5- FHD screen with a resolution of 1920 × 1080, the screen is fine, atmospheric modeling , as for CPU aspects ,the phone using MediaTek MTK6589T quad-core processor , clocked at 1.5GHz, SGX544MP the GPU, data processing and graphics are very strong. 2GB RAM +32 GB ROM is also practical , maximum 32GBTF card expansion supports, it is surprising , and equipped with its own depth of customization Jelly Bean OS 2.0 system ( based on Android4.2). The most important thing is to facilitate the use of the front and rear camera dual 13 million pixel camera , the camera performance is second to none .
    ThL w11 Monkey King with a low cost is very competitive , both 5-inch full HD screen , quad-core CPU, 2GB RAM, 32GB ROM or dual front and rear 13 million pixel camera, is also quite competitive among these high-end flagship products. If you want to have the high-end configuration of the phone, ThL w11 Monkey King is a very worthy of consideration phone.
    #15096
    mingtian00
    THL phone product appears wih the cost-effective, from the first launch of the thl phone to
    today the upcoming THL T100
