THL T6 PRO Review
- This topic has 0 replies, 1 voice, and was last updated 12 years ago by .
In this review, we check out THL’s T6 Pro. This octa-core entry-level phone is definitely worth it for those who plan to buy their first cellphone.
Appearance
The THL T6 Pro has a similar appearance to the THL T6S. This phone weighs about 150g and has a thickness of 8.2mm. It has a micro SD and two regular-sized SIM card slots. At the back, you will find the camera which is well placed, and below it are an LED flash and THL’s logo. Overall, it looks pretty good.
Display screen
The THL T6 Pro sports a 5-inch 1280 x 720 OGS display screen with a pixel density of 320ppi. The quality of the screen is so good that even outside in the sunlight with maximum brightness, you can still see the screen clearly.
Performance and benchmark tests
The following are the results for the THL T6 Pro in the Antutu Benchmark test as well as all of its specifications.
The MT6592M octa-core processor is perfectly compatible with the Android 4.4.2 Kitkat. Even powerful games like Real Racing 3 can be played without any problems.
Camera
The THL T6 Pro’s rear-facing camera works very well. The photos are all very clear with very little noise. Even with little light, the quality is still excellent. With auto-focus, you can also take 8mp photos. I cannot say the same for the 2mp front-facing camera. The LED light also works well.
Here are some samples taken using the THL T6 Pro’s rear-facing camera:
Battery Life
The tablet can last up to 7 hours if you surf the web with full brightness.
Connectivity
It has support for 2G and 3G networks but not 4G, unfortunately.
Conclusion
Overall, this is a great cellphone to have for those who have never owned a cellphone, although it suffers from a few problems such as limited battery life.
