One of the great features of the up and coming USB Type-C ports and plugs is that they’re reversible, making it very easy to use them as you no longer have to check if you’re putting the plugs in the right way. But what people don’t know is that even the older and more commonly used Micro USB plugs have variants that are double-sided or reversible. One example is the BlitzWolf 2.1A Double-sided Micro USB Cable which you can now get through Banggood.com for only US$2.99.
The BlitzWolf 2.1A Double-sided Micro USB Cable features double-sided USB A male and double-sided USB Micro B plugs that allow users to plug them into devices without needing to check if they’re aligned the right way. The cable supports 5V/9V/12V fast charging at up to 2.1A and is compatible with Qualcomm QC2.0, MTK Pump Express Plus, and other fast charging technologies. It’s also capable of data sync speeds of up to 480Mbps.
The BlitzWolf 2.1A Double-sided Micro USB Cable features gold-plated connector heads, a 3.3ft/1m flexible TPE cable which houses the 24AWG power and 30AWG data tinned copper wire cores. It is available in either black or white and comes with an 18-month warranty.
