The Alife P1 Pro Uses the Same Sapphire Crystal Fingerprint Scanner Tech as the iPhon
  • #8541
    Blackview’s recently announced Alife P1 Pro flagship smartphone features a high-end design with high-end specifications. One of those specifications is the device’s home button that also acts as the device’s fingerprint scanner.
    blackview-alife-p1pro-fingerprint-tech-01The home button, which is fit right into the device’s 2.5D arc front glass panel, uses a laser-cut sapphire crystal cover that both protects it and acts as a lens to take highly detailed images of your fingerprint which are then used to encrypt and secure the P1 Pro via a chipset found right inside the home button. This home button fingerprint sensor design and the technology behind it are similar to the ones found on Apple’s popular iPhone devices such as the iPhone 5S, iPhone 6, and their other new products giving the P1 Pro that extra boost in value.
    blackview-alife-p1pro-fingerprint-tech-02blackview-alife-p1pro-fingerprint-tech-03The Alife P1 Pro’s other high-end specifications include a 5.5-inch IPS display with a screen resolution of 1280 x 720 pixels, a 13-megapixel rear camera, a 5-megapixel front-facing camera, a MediaTek MT6735 64-bit quad-core processor, a Mali-T720 GPU, 2GB of RAM, 15GB of internal storage with support for expandability up to 32GB via microSD, and a 3000mAh battery. The P1 Pro also supports 4G LTE, dual SIM standby, Bluetooth 4.0, and GPS. It runs Google’s latest Android 5.1 Lollipop operating system.
    As we’ve previously reported, the Blackview Alife P1 Pro will begin shipping near the end of the month and will be available in either Pearl White or Violet Black.
