Short review of ZTE Nubia Z5S smartphone
- This topic has 0 replies, 1 voice, and was last updated 12 years, 11 months ago by
December 1, 2013 at 11:10 AM #5009
MemberOn November 29th, ZTE has been lauching the nubia Z5s smartphone, along with the nubia Z5S mini android smartphone. The ZTE nubia Z5S is the LTE version smartphone and has good shape and nice configuration.
The interesting is the nubia Z5s is offers with very affordable price and this phone is attract more user, since the phone is offers with only 1999 yuan price tag or around $328 USD price. This phone is potential to compete with Xiaomi phone and now we have a short review of the phone.
The nubia Z5S has nice looking design with high-grade material.
Because in nubia trademarks with red accents, so there are a lot of red body elements, the red phone screen below the Home button is very beautiful, both sides of the red dots are the Menu key and back key, the red light and white body really match.
nubia Z5S has 5 inches screen wih 1080P display with OGS full lamination technology screen reached 443ppi, and on the screen using the sharp CGS + NM2 technology that allows the screen display technology has reached a very high level. Covered with Corning Gorilla Glass v3 to protect this will covered the screen from sratch and impact.
nubia Z5S will be integrated into the phone’s slim designs, that only has 2.67mm borders design, contoured fit the unique curved design, with excellent grip. The body has 7.6mm thickness, the phone body is very handy to grip.
In the side of the phone there is a camera button.
nubia Z5S uses a 13 million pixel camera, a circle of red metal ring as a decoration, highlight the different camera While at the edge of the camera can see “OIS” logo, which is said nubia Z5S supports optical image stabilization feature , the camera when you shoot the picture will be clearer.
In the bottom of the phone cable interface has a metal frame around protection interface, so the interface is more durable, the hole beside the phone’s microphone.
The ZTE nubia Z5S uses Android4.2 operating system, the interface is easy to use and the phone is very comfortable to use one-handed operation.
nubia Z5S one-hand operation mode also uses the thumbnails, when the single-handed operation of small-screen directly on the screen, and then the same operation will be made directly on the big screen, you will feel when in use is very convenient.
From the view of the entire operation, nubia Z5S mainly reflects a simple, unlock the interface has been pressing the unlock button to complete the circle to unlock, open the above mentioned model also requires only one hand to gently shake your mobile phone sideways on it, simple operation of the user can operate to a greater extent.
nubia Z5S added functionality gestures, powerful hardware support allows mobile phones to identify the four-way volley gesture by gesture, the user can complete interactive live wallpapers, answering phones, flip mute and pause functions. Open gestures, then you do not need to touch the screen to complete the operation.
In the phone’s settings interface, we can see nubia Z5S support CDMA / EVDO / GSM / W CDMA network to support 4G networks. But unfortunately because of domestic regulatory requirements, Z5S LTE version can not be compatible with TDD-LTE and CDMA networks, it supports Telecom 3G version Z5S not support 4G version, this is somewhat regrettable, but Z5S is still the largest support network smartphone.
The nubia Z5S uses Snapdragon 800 processor , this smartphone brings powerful performance. While we make this article, we using the prototype smartphone so that’s only got 33,035 score point by benchmark test, but when the phone is launching officially, the final release phone will be got the higher score, it may 35,000 score points.
Says the following in relation to the phone in the camera’s performance, nubia has been on camera has its own advantages, focus and metering before separation performance is very good, on nubia Z5S, not only the continuation of the previous separation of focus and metering function, also joined the white balance adjustment, allowing users to shoot photos of more features.
Figure the square is the focal point of the circular as metering, white balance is an independent diamond
Under professional camera mode, you can adjust the exposure value, the pixel size, white balance and other settings, set the interface is very simple and straightforward, operate more smoothly by comparison.
In the video capture mode, the user can use a separate and independent AF metering features, independent white balance is currently not in video mode adjustment.
If you think these phones allow you to adjust the parameters a bit complicated, you can directly select the phone’s automatic camera mode, in automatic mode, the phone can take up to take pictures, do not need to set parameters.
nubia Z5S also supports panoramic camera, trajectory, passers removed, there is the sound of photographs and other camera mode, allow pictures to be more fun.
These are the simple experience of nubia Z5S smartphone, from the perspective of the first impression to get started, nubia Z5S is the interesting phone. Nubia Z5S is currently in pre-order, offers with priced at 1,999 yuan, the price is worthed so far.
