Samsung S4 clone problem
- This topic has 9 replies, 5 voices, and was last updated 12 years, 7 months ago by
kaamil20.
December 26, 2013 at 2:55 PM #5205
turby85
MemberHello!
I just bought Samsung S4 Clone (mtk6589).
It have problems – sometimes it recognises SIM card, sometimes says there is no SIM card. Even when it recognizes the SIM card, I can’t import contacts – it is loading forever.Also, there is no network. It is supposed to work in 2G 900mhz and 3G 2100mhz used in our country so that is not the problem (I hope). I allready changed the IMEI number with the number from my old phone, whitch worked perfectly. Changing IMEI didn’t help. It can’t connect to network.
If I go to Mobile networks – Select manually it sometimes find some networks and can’t connect, sometimes it doesn’t even find any networks. Choose network automatically doesn’t work at all.Does anyone know what the problem might be or how can I fix it?
Thank you!!!
December 27, 2013 at 7:12 PM #15506Bazabaza
ParticipantWhat is the make of the phone, model number…saying S6 clone does not help? Dont know if it is in your country but changing IMEI number is a criminal offense. It may be that network has detected this change and blacklisted the IMEI number. Change it back and see if your old phone still works. If it does then it can’t be that.
December 27, 2013 at 7:39 PM #15507turby85
MemberI bought this phone on Aliexpress
“Perfect 3G Mobile phone i9500 S4 5 inch android 4.2 mtk6589 Quad Core 1GB RAM Air Gesture Air view S-view Eye control”In settings menu it says Model number: GT-I9500
Old phone still works. Looks like IMEI is not a problem.
I don’t know what else could be wrong?
Android version: 4.2.9
December 30, 2013 at 4:11 PM #15512turby85
MemberProblem solved. Phone didn’t work because SIM card was to old.
March 4, 2014 at 7:39 AM #16091JAGAAN
MemberIam Having GT-I9500 Samsung S4 Copy Phone It showing Internal Storage of 2.46GB & Phone Storage of 10.45GB, but when i connect to usb mass storage mode, its showing 2.46GB only i cant use or transfer files to 10.45GB, pls help
March 6, 2014 at 4:34 PM #16113Bazabaza
ParticipantJAGAAN wrote:Iam Having GT-I9500 Samsung S4 Copy Phone It showing Internal Storage of 2.46GB & Phone Storage of 10.45GB, but when i connect to usb mass storage mode, its showing 2.46GB only i cant use or transfer files to 10.45GB, pls helpMight have had the memory report tweeked. It looks like it might a 4 gig phone tweeked to give a higher capacity. try installing Antutu or similar and see what it reports
March 7, 2014 at 6:42 AM #16114JAGAAN
MemberBazabaza wrote:JAGAAN wrote:Iam Having GT-I9500 Samsung S4 Copy Phone It showing Internal Storage of 2.46GB & Phone Storage of 10.45GB, but when i connect to usb mass storage mode, its showing 2.46GB only i cant use or transfer files to 10.45GB, pls helpMight have had the memory report tweeked. It looks like it might a 4 gig phone tweeked to give a higher capacity. try installing Antutu or similar and see what it reports
Thank u for ur help, iwill check & reply
March 10, 2014 at 8:37 PM #16166Bazabaza
ParticipantDoes the PC display anything when you connect? this might also be a partition issue with the memory. The larger partition may not be formatted.
http://www.chinaphonearena.com/forum/Thread-Tool-App-for-repartitioning-your-phone-s-internal-memory
This looks similar, different reason but the solution might work.March 22, 2014 at 5:41 AM #16324vijayinweb
MemberHello..everyone…
I have samsung galaxy s4 I9500 clone…my phone was getting hanged..so i just did restore Factory settings…not while starting the phone it is not showing start up samsung logo..what to do..?April 1, 2014 at 6:59 AM #16399kaamil20
MemberYou get what you pay for. Buy cheap crap, get cheap crap performance.
