Rooting unknown phone
- This topic has 10 replies, 11 voices, and was last updated 12 years, 6 months ago by
1949deal.
June 15, 2013 at 10:22 AM #4018
putti71
MemberHi all together!
I have a fake Note 2 from china, unfortunately the kernel is manipulated to show wrong model and stuff.
“Hardware : MT6575 (SMDK4x12 is Fake!)
Model : GT-N7102
Build number : JRO03C.N7100ZSALIA
Build date UTC : 20130419-034135
Android v : 4.1.1
Baseband v: MAUI.11AMD.W12.22.SP.V17, 2012/11/28 12:38
Kernel v : 3.0.31-178067 (se.infra@SEP-113) (gcc version 4.4.3 (GCC) ) #1 SMP Fri Apr 19 11:40:07 CST 2013″I tried all different kinds of root methods, all without success.
Is there anybody out there who can help me out there?
I think with splash tool it could work, but I dont know to to manage it.
BTW its a dual SIM Phone
Any help would be appreciated!July 25, 2013 at 9:45 PM #13906elenai
Participantputti71 wrote:Hi all together!I have a fake Note 2 from china, unfortunately the kernel is manipulated to show wrong model and stuff.
Model : GT-N7102
Android v : 4.1.1
Any help would be appreciated!I have same problem.
August 14, 2013 at 7:28 AM #14073molekwasj
MemberDownload and install “MtkDroidTools_v248” to your computer/laptop, open it and connect your phone it has an option to root your phone.
On your phone go to settings, developer options, activate developer options and activate USB debugging. The software will read your phone and you will be able to root it, you can also change IMEI. When you change IMEI use your old phone and destroy it. If it is a dualism you need two old phones/dualism to replace IMEI. Some of these phones do not have a valid IMEI to connect to network.August 26, 2013 at 4:10 PM #14183eza
ParticipantSlt a tous et a toutes j’ui un nouveau membre alors j’aimerai bien que vous m’aidiez ,, je sui en SEI ben voila un client ma apporté son telephone model GT – S7562(samsung) sous android mais contrefaçon … le blem c que a l’insertion d’une puce le telephone se plante au demarage en affichent ANDROID et reste là …. , puisse svp acquerir de votre connaissance pour y faire face . merci cordialement
September 3, 2013 at 7:01 AM #14255albertcane
ParticipantYeah, i think that’s the best idea.
September 20, 2013 at 2:19 PM #14461davidexct
ParticipantI do not think that you’ll be able to root your fake samsung galaxy note 2 devices as they do not have official firmwares in them and so they would not be supported by rooting software such as unlock root. Rooting a Android device from any application or source other than Unlock Root is very risky and can easily brick your snartphone so I would not recommend you to root your Android Smartphone.
September 21, 2013 at 4:42 PM #14463dester
Participantcomment rooter l’alcatel ot 997D qui tourne sur android 4.0.4
October 7, 2013 at 1:16 AM #14611sm15gli
Memberdavidexct wrote:I do not think that you’ll be able to root your fake samsung galaxy note 2 devices as they do not have official firmwares in them and so they would not be supported by rooting software such as unlock root. Rooting a Android device from any application or source other than Unlock Root is very risky and can easily brick your snartphone so I would not recommend you to root your Android Smartphone.I have the following SGNote2 Clone (read using MTKDroidTools):
Model : GT-N7102
Build date UTC : 20130807-055316
Android v : 4.2.2
Kernel v : 3.0.31-178067 (se.infra@SEP-113) (gcc version 4.4.3 (GCC) ) #1 SMP Fri Aug 9 13:46:27 CST 2013
Uboot build v :
LCD Driver IC : 1-otm8009a_6575_dsiIt is rooted and has CWM recovery
October 30, 2013 at 4:39 AM #14807babbbyyyy
Participantgreat post sm15gli
March 21, 2014 at 7:35 PM #16323jl brown
MemberI have used kingo root to successfully root the following devices: dragon touch 16gb elite mini r8 (v88s), Imuz 9.7″ Q9, ZTE force n9100. It may take a few goes at it, but it gets the job done well, on devices that seemed otherwise unrootable.
April 2, 2014 at 9:19 AM #164121949deal
Participantwe will also provide you the root and ROM tools.
