Rom for Doogee valencia dg800
- This topic has 0 replies, 1 voice, and was last updated 12 years ago by .
This year, Doogee has released many models for customers’ choices, but this one Doogee DG800 is the classic 4.5inch quad core smartphone, many customers have ordered it, and now we tell you the good news that it has 8% off for 6 colors at $111.99. And we also provided you the latest ROM of Doogee DG800. Just follow the procedures below.
Download these files:
http://www37.zippyshare.com/v/82645339/file.html
Then download the original rom file:
http://pan.baidu.com/s/1sjLO0Br
Install Now!
1) Extract both zip files.
2) Place SuperSU Pro v1.00.apk and UPDATE-SuperSU-v1.99.zip file (found under “Root DG800″ folder) in the root of your sdcard.
3) Find the recover.img file under the “Root DG800″ folder and replace the original recovery.img file under the original rom folder with it.
4) Open flash tool.exe and load the scatter file from the original rom you downloaded, uncheck all boxes of the list in the bottom part, but leave RECOVERY checked, accept any warnings.
5) Click on download, remove the battery of your phone, place it again and connect it to the pc. It should detect it automatically and start the process, you must have drivers installed of course.
6) When it is finished, disconnect the phone and turn it on while pressing volume +. The phone will turn on and a little menu will appear on the bottom part, with the volume buttons, make sure it is on Recovery Mode.
7) When on recovery mode, select install zip from sdcard and install UPDATE-SuperSU-v1.99.zip.
When finished, reboot the phone, install SuperSU Pro v1.00.apk and it is done.
Therefore, if you have a Doogee DG800, and want to root it, or update the firmwave, you can do as we told you. Your smartphone will become more faster. Just enjoy it from 1949deal now.
