Review of OPPO Find 7 Android smartphone
- This topic has 0 replies, 1 voice, and was last updated 12 years, 7 months ago by
March 23, 2014 at 11:10 AM #5583
MemberOPPO has already release their new flagship samrtphone OPPO Find 7 on March 19th, 2014. The phone has been exposed before the officially release.
Before now, there are many rumored that the new OPPO Find 7 will has packs with 5.5 inches 2K screen, OPPO called “super-screen 2.0.” Compared to the earlier news that is another domestic smartphone Vivo Xplay3S that also packs with 2K screen pixel , OPPO Find 7 is equipped with a 5.5 inches screen at the same resolution, the pixel density as high as 538PPI, this make the OPPO Find 7 becoming the most sophisticated Android smartphone.
In addition to eye-catching screen, OPPO Find 7 is offers with two kind of model, the Standard Edition uses Qualcomm Snapdragon 801 (MSM8974AC) quad-core processor, clocked at 2.5GHz, with 3GB +32 GB storage combination, support up to 128GB storage card expansion, the battery capacity is 3000mAh (removable), weighing about 173g; The phone is also coupled with 5 megapixel front facing camera and 13 megapixel rear facing camera, that support multi-frame sampling synthesis technology can synthesize up to 50 megapixel picture, but also 4K video recording.
OPPO Find 7 also supports flash charge, using their own VOOC flash charge technology, with a 7-pin charging port, four times faster than a regular smartphone charger method. OPPO Find 7 is also support for TD-LTE and FDD-LTE dual-4G network, and supports WCDMA and TD-SCDMA dual 3G network.
OPPO Find 7 Standard Edition and lightly armed version of the argumentStandard Edition Lightly armed version CPU Qualcomm Snapdragon clocked at 2.5GHz MSM8974AC Qualcomm Snapdragon clocked at 2.3GHz MSM8974AB RAM 3GB 2GB ROM 32GB (supports up to 128GB Expansion) 16GB (supports up to 128GB Expansion) Screen 5.5 inches 2560×1440 resolution 538PPI 5.5 inches 1920×1080 resolution 403PPI Camera Rear 13 million pixel camera Sony IMX214 sensor can capture the first 50 million pixel photos 32s slow shutter Front 5000000 System Color OS 1.2 Battery capacity 3000mAh (removable) 2800mAh (removable) Network standard GSM, TD-SCDMA, TD-LTE, WCDMA, FDD-LTE Features Bass’s first MaxxAudio tick NFC chip VOOC flash charge paid smart bracelet O-Band Price 3498 yuan 2998 yuan Oppo is offers two smaretphone model, and the low version is different with the standard version. While both phone using the same 5.5 inches screen size, but the resolution is different and the low version is down to 1920×1080 resolution, using Qualcomm Snapdragon MSM8974AB quad-core processor with a 2GB of RAm and 16 GB of internal storage portfolio, the battery capacity is 2800mAh, weighing about 170g. Like the rest of the configuration and the standard version, the phone is offers for 2,998 yuan price or around $481 USD price.
Adopting the new screen technology
At the OPPO Find 7 conference, OPPO has announce the new scren technology and that screen is using the new aesthetic design. And the phone has 5.5 inches with 2K resolution that’s called as “super-screen 2.0″, with 538ppi, what the screen can offers? let’s take a look below:
OPPO Find 7in the overall, OPPO Find 7 has same design with the previous OPPO Find 5 smartphone, including the bottom crescent, but the Find 7 offers more depth and celar screen with 5.5 inches with 2560x1440with 538PPI pixel density. The phone has nice finshing touch;
Top of the fuselageUpper front of the phone is still the earpiece, front camera, proximity sensor combinations, which is generally smart phone design. Particular point is that compared to many manufacturers logo printed on the top near the handset . And the camera is offers with very nice and high quality picture, with 5 megapixel front facing camera, this lense will be loved by the user who like to take selfie pictures.
The bottom of the fuselageThe bottom design of OPPO Find 7 is using the virtual soft button that look nice than using the physical button, this design is mix with the flat design and look very comfort in hand
On the left side of the fuselage for the power / lock screen button
As the volume keys on the right side of the fuselageThe side body is using metal material, is make the OPPO Find 7 very comfort togrip and strong body. And there is another part to ipen the back cover.
Top of the phone
Bottom of the phoneThere is a micro USB port to charger the phone or transfer the data from phone to PC, and the phone has VOOC charge method that the user can charge the phone battery in extremly fast, while the OPPO Find 7 battery has 3000 mAh. The back cover has nice design with carbon pattern with camera and Dual LED flash light.
The phone back body, there is camera lense and dual LED flash light, the phone is rumored as a high megapixel camera since appear with 50 megapixel camera picture example recently.
OPPO Find 7 has good sound quality since adopt the new MaxxAudio bass technology, equipped with the world’s top sound solutions – MaxxAudio Mobile, successfully resolved the problem of insufficient bass, this program is the technology gains Grammy Awards, can provide a solid rich bass.
You can touching the metal side of the body to open the back cover, when you open this parts, there is Micro-SIM card slot, memory card expansion slot hat support dor 128GB of data, but the 3000mAh battery is non removable.
You can see OPPO Find 7 fluency in the system, aspects of pictures, screen effects, have good performance, follow-up, we will bring a more detailed evaluation of the real machine video.
Comparing the OPPO Find 7 low version vs high version
What’s the different between OPPO Find 7 low version and high version?, the main different is in the CPU, memory and screen. Whil the other part is same.
White version of the back cover are diamond lines
Lightly armed version of the back cover is black matte texture
(Left) White Standard Edition, (right) Black Standard EditionScrub lightly armed version of the design for the back, and not the standard version of the drawing and design classes skin looks are completely different feeling, Find 7 Standard Edition feel noble and mysterious, but lightly armed version Find 7 feel stylish and lively.
Black and white version of the Standard EditionIn fact, the details of exactly the same as the standard version, the position of the camera, logo, the speakers are not changed.
The body design exactly the same, but although the screen is 5.5 inches in size, but the standard version has 2560 x1 440 resolution, while the low version has 1920 x 1080 resolution, but this aspect is not too significant for most user,
There is many samrtphone that also offers wih2K screen resolution, while OPPO FInd 7 is also offers with the 2K resolution screen, and OPPO Find 7 owns 5.5 inches of 2K resolution, screen finesse PPI has leapfrogged 500, becoming temporarily world’s most sophisticated screen phones.
More closer with Color OS 1.2 system
OPPO Find 7 is running Android 4.3 operating system but theeis a Color OS 1.2, system UI to make the OPPO FInd 7 more user friendly and interesting.
Color OS is support OTA upgrade. there is a noctification when the upgrade packages isready. The user can change the gesture to make the system is understand what the user want.
MaxxAudio Mobile on OPPO Find 7.
OPPO Find 7 is also has voice assistant.
The Benchmark
OPPO Find 7 has a standard version and the low version, the main difference between the two is in the configuration. Standard verson is equipped with a clock speed of 2.5GHz Qualcomm Snapdragon 8974AC chip memory capacity of 3G B, while the built-in storage space for the 32GB; rather lightly armed version of the configuration a little bit weak, equipped with 2. 3G Hz high-pass Xiaolong 8974AC chip, 2GB RAM / 16GB ROM . Both versions support up to 128GB of memory card expansion.
Standard Edition to run sub and system information
Lightly armed versionHere is the different scroe point between the low-end version with high-end version of Oppo Find 7 smartphone
Super innovative camera experience
While OPPO Find 7 has good quality Sony’s latest I MX2 14 sensors, effective pixels 1300W.
here is the another picture example taken by OPPO Find 7 smartphone
The camera is also comes with very nice camera apps, the user can select the different filter for different situation.
Summary:
OPPO Find 7 is the nice smartphone that comes from domestic market, but this phone is also ready to compete with another rand in the global market. With the new 2K screen display, make the phone is amazing and very nice looking
In addition, the processor and memory and other feature is very nice, you can see the VOOC flash charge, MaxxAudio bass technology, innovative filming techniques, 128GB expansion, therefore OPPO Find 7 is not a pile of hardware, mobile phones, but pay more attention to user experience and practical phone.
