PIPO T8 Affordable 3G Tablet
- This topic has 0 replies, 1 voice, and was last updated 12 years, 1 month ago by .
PIPO, one of the best Chinese Electronics manufacture has announced new 2-1 Android multimedia phone tablet that designed for a budget conscious costumer, named PIPO T8 3G tablet. Yeah, comes with two SIM card slot that can work simultaneously and boasts a 6.44 inch Full HD Capacitive display, the T8 tablet from PIPO not only provides very stunning viewing experience, but also help you to stay connected with family or friends with video calls or phone calls wherever you go without need to worried about WiFi Hot Spot Area.
Yeah, like common Chinese based tablet’s on its class, PIPO T8 6.44 inch tablet is comes with a plastic material for casing. But with solid black color for entire casing, this model looks more solid and robust than they are. The 239 gram tablet has dimension in 7.13 x 3.62 x 0.16 inch (181 x 92 x 4 mm). Its not the slimmest Chinese based tablet but still comfortable to carry around and easy to grip in one hand. According to the manufacture, the Lithium 3000mAh battery on this model provide more than eight hours of battery life between charges.
Based on the new ARM Cortex A7 Octa Core processor with Mediatek MTK6592 octa core chipset and clocked around at 1.7Ghz, the latest PIPO Phone Tablet delivers more than enough performance you will need for running latest Android multimedia and productivity applications, along with modern Android games. Inside, the 2GB of RAM that combined with the 4.4 version of Google Android KitKat for the operating system provides faster and smoother performance for handling most demanding Android games and software than its competitors. Yeah, the 32GB of internal storage is not promised plenty of storage space. But if needed, you can easily expand the memory space with extra 64GB of storage from TF/SD cards.
Infos: http://www.tinydeal.com/pipo-t8-644-android-44-mtk6592-3g-phablet-w-gps-bluetooth-p-136554.html
