When it comes to very cheap phones, they usually lack in a lot of different departments and that’s why we are not really interested in them. However, Oukitel has some intentions to change that with their latest U2 model. Will it be another cheapo device with too many “compromises” or will it be a cheap phone worth looking at?
We wanted to say thanks to Comebuy.com for sending Oukitel U2 for a review.
Buy Oukitel U2 from Comebuy for $93.18
Oukitel U2 Review: VIDEO
Oukitel U2 Review: SPECS
| Display |
5″ 960 x 540 (qHD) |
| Processor |
MTK6735 64bit Quad Core, 1.0GHz, Mali-T720 GPU |
| RAM |
1GB |
| Camera |
5MP Front/8MP |
| Connectivity |
Bluetooth, 3G, 4G, GPS, WIFI, GSM,EDGE, GPRS, UMTS, HSPA, HSPA+ |
| Battery |
2.050 mAh (removable) |
| Dimensions |
14.3 x 7.05 x 0.83 cm / 5.62 x 2.77 x 0.33 inches / 150g |
| OS |
Android 5.1 |
| Storage |
8GB (expandable via microSD card slot up to 32GB) |
Oukitel U2 Review: UNBOXING
The call quality is surprisingly decent for a cheap phone and the signal reception is better than average. The 4G connectivity may not be the fastest but it is working.
GPS lock speeds are pretty fast, Wifi and Bluetooth are working fine and I am quite impressed that the Oukitel U2 doesn’t have major connectivity issues like some other cheap phones.
Oukitel U2 Review: BATTERY LIFE
In theory, 2050mAh battery should perform good given the fact that the phone does not have a powerful chip and it does not need to push too many pixels.
In reality, the Oukitel U2 will last you a full day if you are not a heavy user and it has a decent over 4 hours screen-on time.
Oukitel U2 Review: CONCLUSIONS
So here it is, the $90 Oukitel U2. If you are on a tight budget and looking for a phone that has a great design and build quality, does all the basic tasks well, has a great user interface performance, decent call quality and battery life, this phone may be for you.
However, the Oukitel U2 would not be your next device if you love taking a lot of pictures and love playing the latest 3D games.
Still, despite these shortcomings, which could be a deal breaker for some, the Oukitel U2 is a really decent offering in the price range of under $100 unlocked.
