[size=large]Oukitel K4000 is an indestructible 4G smartphone, if you don’t believe it, check the videos below. Moreover, it has good specigications and decent design. Of course, like the title mentioned, this device also has a long-living battery but at a very cheap price.
Oukitel K4000 is available in black and white colors. And its body is very large because of its big battery and metal bar. The volume, unlocking buttons are on the right side while the battery input is on the lower side, and an AUX input for headphones and audio devices are on the top. There are also three touch buttons on the lower area of the phone: the classic Menu, Home, and Return. Just keeping hold Home button you can even open applications managing. By the way, the device has a dual micro-sim system.
The screen is capacitive with a 5.0 inch screen size made of Gorilla Glass 3, 1 mm bezels made and 5 D, ensuring an excellent visual definition (1280×720 HD). Multi-Color Touch screen has a 5 points capacitive multitouch display, which is very responsive and grants a fluent finger touch experience. The Oukitel K4000 also comes with Android 5.1 lollipop system and 64-bit MediaTek MTK6735 Quad Core processor. The GPU integrated within the smrtphone is MALI-T720. Further more, the device has 2GB of RAM and 16GB of ROM, which is enough for you to run the daily operations and multitasks. Besides, its external memory can be extended up to 32GB.
The cameras are 13.0 MP rear camera with 2.5D Arc Screen and a flash, as well as 5.0MP front camera. The picture formats includes JPEG, GIF, BMP as well as the PNG formats. The video formats supports 3GP, MP4 and WAV. The device also comes with a speaker, a Micro USB slot and 3.5mm Audio jack.
Oukitel K4000 has Smart Gestures function, allowing you run some functions directly with simple gestures. Face Beautify function is within the device to improve your self-portrait photos quality when using your front camera to take a selfie. The screen employs a Zn Magnesium alloy frame which combines the CNC technology and adds to the artistic beauty of the frame.
[size=large]Here’s the band of Oukitel K4000.[/size]
2G: GSM850/900/1800/1900 MHz
3G: WCDMA 900/2100 MHz
4G: FDD-LTE:B1( 2100)B3(1800) B7(2600) B20(800)
There are power adapter, USB cable and an English manual in the box and Oukitel K4000 has 4000 mAh battery, which is powerful enough to run the phone. In short, the Oukitel K4000 is a smartphone with a decent design, excellent specs, large battery and a very affordable price, so why not bring it home if you are planning to get new buddy?
[size=large]Buy Oukitel K4000 for $113.99 at 1949deal.com[/size]
[video=youtube]https://www.youtube.com/watch?v=T8qMLWN07Vs[/video]
[video=youtube]https://www.youtube.com/watch?v=yKyMs4l_uks[/video]
[video=youtube]https://www.youtube.com/watch?v=G8yKa8TLigk[/video][/size]
