Original K4000 vs forthcoming K4000 Pro, whats improved?
- This topic has 0 replies, 1 voice, and was last updated 10 years, 10 months ago by
January 6, 2016 at 11:10 AM #9996
Original K4000 vs forthcoming K4000 Pro, lets see what Oukitel have improved.Oukitel are all set to release the new improved K4000 Pro, lets have a look at the specs of both phones and see what improvements Oukitel have managed to make to the new handset.
The new K4000 Pro will be seen by many as more of a K4000+ the newer handset sees some styling tweaks and some under the hood enhancements that should make the original K4000 even better.
So whats not been changed?
Both the original K4000 and the newer K4000 Pro feature 5-inch HD displays (1280 x 720p resolution) and are powered by 1ghz Quad-Core 64bit Cortex-A53 Mediatek MT6735P processors, these are not the most powerful CPU’s but should do an ok job for most everyday needs.
Ram and Rom configurations are the same between both handsets with 16GB ROM and 2GB RAM and both feature the same camera pairing of 8.0 mega pixel (13 Mega Pixel interpolated) rear facing camera and 2.0 Mega Pixel (5 Mega Pixel interpolated) front facing camera.
Like the original K4000 the newer K4000 Pro will come with Android Lollipop 5.1, with a confirmed upgrade path to Android Lollipop 6.0 on the K4000 Pro.
Given that both handsets share a lot of components in common, it would be a fairly safe bet that the original K4000 will also see the upgrade to 6.0
USB OTG functions like reverse charging will also make a return on the K4000 pro, when used with an OTG cable.
So whats changed?
The original OUKITEL K4000 featured a large removable 4000mAh battery, whilst the K4000 Pro sees an increased to 4600mAh whilst still remaining removable.
In order to make maximum use of the battery without making charge times to long, Oukitel have increased the original K4000 charging from 5V/1.0A to 5V/1.5A this is a 0.5A increase in charging power and should see both the K4000 Pro and the K4000 fully charged within 3-3.5 hours.
Oukitel have also improved network coverage on the K4000 Pro, both handsets support the following bands, 2G(GSM850/900/1800/1900MH) and 3G(WCDMA 900/2100MHz) 4G FDD LTE B1/3/7/20 (2100/1800/2600/800MHz). the newer K4000 Pro adds one more band: B8 (900MHz).
There have also been a few structural changes K4000 pro, the screen is now 1.1mm thick, making the glass more durable and up to three times stronger, the K4000 Pro also has an improved corner design to its 2.5D CNC ARC craft metal design, that should help the phone to further resist damage when dropped.
Another improvement to the phone comes in the styling department, the Oukitel K4000 Pro now has a crocodile leather textured back cover, this should hopefully make the phone comfortable in the hand whilst also helping to reduce the chances of dropping the phone.
As soon as a review sample finds its way to me, I will do a full handset review.
So what do you guys think? does the Oukitel K4000 Pro have enough extras for you? are you a K4000 owner? would you consider purchasing the new model for its improved battery? or will you wait for the K6000 Pro? or perhaps one of the other great phones that are due this year.
Hopefully Oukitel will continue the strong push they had at the end of 2015 and will start to bring out more 2016 phones with processing power to match their impressive batteries.
For now please leave comments and questions below.
Regards Shanos
The original K4000 can be purchased here
Original article posted on gadgetz.tv
