Pictures of the unboxing experience of the recently launched OPPO R7 Plus have been published online showing off the new device and everything else that comes with it.
The OPPO R7 Plus comes in a fairly simple yet large box featuring the signature OPPO green and white colors as well as a drawing of the device on top. Opening up the box reveals the R7 Plus itself which fits snugly into the box. Additionally, the R7 Plus comes with a pre-installed screen protector.
Under the device is the included pin used to remove its SIM card tray which is attached to a removable white inner box. The removable white inner box contains the R7 Plus’s manuals, a voucher for OPPO’s online mall, and a transparent phone case for protection.
Removing the white inner box reveals the rest of the device’s accessories which include an AK775 USB charging adapter, a USB charging cable, and an OPPO M1516 IEM headset which comes with a few sets of ear plugs.
The R7 Plus is a bigger and higher-end version of the OPPO R7. It features a large 6-inch AMOLED screen with a display resolution of 1920 x 1080 pixels, a MediaTek MT6795 64-bit 1.5GHz octa-core processor, 3GB of RAM, 32GB of internal storage, and a 4100mAh battery.
It’s also equipped with a 13-megapixel rear camera with laser autofocus and optical image stabilization, an 8-megapixel front-facing camera, and is powered by Android 5.0 Lollipop with OPPO’s Color OS 2.0 on top.
The R7 Plus also features a slightly different dual SIM card tray which supports two nano SIM cards while the original R7 supports a microSIM and nano SIM card combination. Both secondary nano SIM card slots also support microSD cards up to 128GB.
The OPPO R7 Plus will be available on July 23 at a proce of 2999 Yuan.
