OnePlus 10,000mAh Powerbank Sandstone Black Unboxing
  • #8152
    On the anniversary of OnePlus, they released their new product, OnePlus 10,000mAh powerbank. It uses ATL lithium-ion polymer batteries with a capacity of 10000mAh, priced at 89 yuan. Today, the beautiful black color version of the same was unboxed by Sina Science and technology.
    OnePlus Powerbank weights 221g, It is portable with a size of 142.8 * 72.6 * 16.2mm. Marked capacity is 10000mAh with energy of 37Wh . It can charge OnePlus One 2.5 times, iPhone 6 4.4 times, iPhone 6 Plus 2.7 times and iPhone 5s 5.5 times.
    The coating on the black version of OnePlus Powerbank is very similar to OnePlus One. it is made up of same material which is used in OnePlus One sandstone black back cover and naturally, the texture feels very good.
    In addition, the power supply uses a shake-known power of innovative design. There’s no mechanical power button and the powerbank retains four LED lights which shows battery life remaining: 100%, 75%, 50%, and 25%.
    The Oneplus 10,000 powerbank comes with a MicroUSB charging port and two USB outputs. Inputs and outputs are at 5V 2A.
    So what do you think about the new powerbank from OnePlus? Looks beautiful right?
    s_1fdd2823dbc14f6d95ffc357b22fc976 s_9ecf9d34b23b4f9c941bc2454cadc0bd s_460e0d9d8be5434e91ef2d5472c63b78 s_5422a17c3e3f4cb9a2a7c4b722a1f70b s_48160c37e4b64ee4808aefd156263b3b s_a5a2903094c14019b6a2ef44001795f7 s_adeb62fe40984d4dbfede809f02adf1c
