Onda V989 review — The most Powerful Android Tablet
  • #6707
    TinyDeal.com
    [size=medium]Onda V989[/size] is the first Onda’s tablet, it powered by an AllWinner A80-T 8-core processor at 2.0GHz. The Allwinner A80-T octa core processor that paired with 2GB of RAM provides ultimate performance for hard multimedia tasks. There is also a 32GB of internal storage that gives plenty of storage space. Of course, the Onda Retina’s tablet also shipped with a TF card slot.
    Onda V989 octa core owns a 9.7 inch Capacitive Retina touch screen display and support a 2048 x 1536 pixels native resolution. The Retina display that paired with chipset that supports 4K video playback offers up to 178 degrees visible angle with 10-point touch support.
    On the front and back side, you will find two high resolution camera. The front facing 2.0 megapixel camera perfect to make Skype chats or self recording, while on the back, the 8.0 megapixel rear auto focus camera provides very crisp and natural color for capture photo and 720p video recording.
    The built-in Lithium 8000 mAh battery will gives between eight hours to ten hours of battery usage between charges. its dimensions are 239 x 169 x 8 mm and weighs 490 g.
    Running on Android 4.4 KitKat, the V989 tablet also comes with gravity sensor, multi language supports, File Manager, Office Suite, Task Manager, Android Webkit, Calculator, iReader and more.
    [size=x-large]http://www.tinydeal.com/onda-v989-97-android-44-a80t-tablet-pc-w-miracast-p-132523.html[/size]
