Nubia Prague S Announced, Features 2.5D Glass Body, SD615 & Eye Recognition
  • #10080
    Recently, Nubia revealed via its Weibo page that it was going to announce a new model in the company’s aesthetic Prague series, called as the Nubia Prague S. Like promised, the company has taken the wraps off the device a couple of hours ago in China. The device starts at a price tag of 2399 Yuan ($364), which tells us that the company is targeting the upper mid-range segment with this device.
    nubia prague s 02
    Like the beautiful My Prague model launched last year, the company has paid special attention on the overall design of the new Prague S. The phone is thin and comes with 2.5D glass on both the sides, along with a metal frame. So, the overall design of the phone looks quite attractive. Plus, you get two color options to choose from, namely white and gold.
    nubia prague s 01
    As for the hardware specs, the Prague S model comes with the mid-range Snapdragon 615 chipset under the hood. Unfortunately, this is not a chip that we expected to be inside a $364 smartphone, but then if you are not a power user, the chip should suffice just fine. However, in the memory department, the company does not disappoint. You can choose between two storage options, 3GB + 64GB or 4GB + 64GB. It’s good to see that both versions feature large 64GB internal storage. As for the display, you get a compact 5.2-inch FHD 1920 x 1080 pixel resolution Super AMOLED display.
    nubia prague s 03
    Nubia smartphones are known for their cameras, and this particular device does not disappoint, at least in terms of specs. The Prague S comes with a 13MP Samsung ISOCELL sensor with 5P Lens and fast 0.2s focus. Further, you have the company’s popular NeoVision 5.2 software which will enhance the camera experience on the device. Up front, you have a powerful 8MP selfie camera with special features such as manual whitening, face lift etc. Further, the dedicated camera button on the left will make sure that your selfies come out perfect.
    nubia prague s 04
    As for the connectivity features, you have the usual stuff like Wi-Fi, Bluetooth, along with Hi-Fi audio. The battery is decent, with a capacity of 2200mAh. It helps that the phone supports fast charge. The company claims that 10 minutes of charging will give you 25% of charge.
    Other highlighted features of the device include support for the company’s FiT touch technology (Frame interactive tech), which was found initially on the Nubia Z9 and Eye recognition. So, no fingerprint sensor on board. The phone supports dual SIM dual standby with 4G LTE.
    Considering its 2.5D glass body and the specs, we might think that the OnePlus X turns out to be a good competitor for the device. So, for the addition of Eye Recognition, Hi-Fi and some other features, do you think the Prague S is worth paying $364?
