Nubia My Prague Unboxing Pictures Published
- This topic has 0 replies, 1 voice, and was last updated 11 years, 3 months ago by .
It’s only been a few days since the Nubia launched its My Prague smartphone to the rest of the world and today unboxing pictures of the new device have been published online.
The packaging of the My Prague looks very simple from the outside. It is a simple and plain white box with the company’s logo in the middle. Removing the top unveils an inner gold-colored box with a white top that features the My Prague name to the right and holds the device itself to the left. Removing the white top that holds the device unveils the device’s accessories which only include a USB cable and a USB charging adapter.
The My Prague features a full metal body that measures only 5.5mm thin and uses a 2.5D arc glass panel with a size bezel of only 1.3mm around its 5.2-inch full HD 1080p Super AMOLED display. My Prague also features a Qualcomm Snapdragon 615 octa-core processor, either 2GB or 3GB of RAM, and either 16GB or 32GB of internal storage. It also supports dual SIM dual standby and features one hybrid dual SIM slot which can support either a micro SIM or a microSD card up to 128GB.
The My Prague is also equipped with a 13-megapixel rear camera, an 8-megapixel front-facing camera, an AK4375 Hi-Fi audio chip, and a 2200mAh battery. The My Prague runs the latest Android 5.1 operating system with Nubia UI 3.0 on top of it and comes with the same FiT border technology found on the Nubia Z9 smartphone which allows users to access some of the device’s functions such as brightness and volume adjustment by sliding their finger along the device’s side bezel.
The My Prague is available in a Standard and Elite version that comes in Silver and Gold, respectively. The Standard version comes with 2GB of RAM, 16GB of internal storage, and is priced at 1799 Yuan while the Elite version comes with 3GB of RAM, 32GB of internal storage, and is priced at 2499 Yuan. Nubia plans to start shipping the device starting July 23.
