NO.1 NOTE 4 Smratphone Hands on
- This topic has 0 replies, 1 voice, and was last updated 11 years, 11 months ago by .
Recently I had a chance to test NO.1 NOTE 4, it looks almost exactly like Galaxy NOTE 4, for one-third of the price and most people wouldn’t be able to tell the difference but a logo.
[IMG]https://lh4.googleusercontent.com/SnKjrueUHnYqo7s98jVO49tjiIOaC9o71AqNvV5vMP8=w299-h214-p-no[/IMG]
Ubboxing
Opening the box was pretty easy and so was the process of disassembling everything. In the box, you get the phone,a battery, a charging adapter, a MicroUSB cable for charging and transferring data to and from your phone to the PC, a screen protector and finally, the user manual.
[IMG]https://lh3.googleusercontent.com/lJrdxO0souWWMtkbduPG2oYAPMhvZpyt2rLWLfzoTfU=w306-h214-p-no[/IMG]
Design
The size of the smartphone is 153.5×78.6×8.5mm, on the front, you have a 5.7 inch screen with the ear piece, front camera and the sensor above the display. Below it, you have a bar for the capacitive keys. on the right side is the power button and on the left are the volume controls.
[IMG]https://lh6.googleusercontent.com/ixMCWoU5mdu9E04BksSuGj_xm2sO9osHX-rWjmwpP-8=w298-h214-p-no[/IMG]
[IMG]https://lh6.googleusercontent.com/wC2I75oW5LtZT1oT1ctSVt5RZ_06Kgq95s88f0jqEV8=w356-h214-p-no[/IMG]
Specs
5.7-inch 1280*720p HD display
MTK6582 Quad-Core 1.3GHz processor
Mali-400 GPU
1 GB of RAM
8GB of ROM, microSD card support 128G
2800 mAh Li-Po battery
Android 4.4.2
13MP rear camera, LED flash
5MP frontcamera
[IMG]https://lh4.googleusercontent.com/-sqvwxeOMcxALhfGyiPMAYXZnz17cKFbGHUX8gEng-g=w116-h207-p-no[/IMG]
[IMG]https://lh3.googleusercontent.com/kEi0BNGv-2kkjw8SDxPiCZk7NZEZ6SoJ2JKdTojKPjI=w116-h207-p-no[/IMG]
Connectivity
The Valencia is a 3G budget phone and has all the connectivity options you would expect. There is Wi-Fi ( 802.11 b/g/n), Bluetooth, 2G GSM and 3G. The device is dual SIM and supports 3G on 850 and 2100MHz.2100 Mhz is the most common 3G frequency and should work in most places around the world, however a lot of carriers also use a secondary 3G frequency range.
[IMG]https://lh5.googleusercontent.com/Nl76VBcxfyhwk3ZRAHsh3WvPCRY_XAmqk653y8GhrhA=w116-h207-p-no[/IMG]
[IMG]https://lh4.googleusercontent.com/9AOqfrbNJ4IaNGaXwuYp8KsF6numVpP16M5diOTdoa8=w116-h207-p-no[/IMG]
