No.1 D5+ smartwatch introduction
  • #11738
    No.1 is the only Chinese manufacturer that delivers complete smartwatches with a real OS instead of the Java ones found on cheap devices. It may not have managed to license the Android Wear from Google, but instead, the company uses full Android OS. That means that it brings with it all the apps found on it and this is the case with the new No.1 D5+ that features Android 5.1.
    No.1 D5+
    The D5+ is the successor of the D5 as its name suggests and has the same 1.3″ 360×360 display. The similarities are just that, as all the internals are different. The new model carries a quad-core MTK6580 SoC with 1GB RAM and 8GB of internal storage. The battery is 450mAh that should be enough for about 2-3 days of use.
    No.1 D5+ 2
    The design is also different although it remains circular. It is more elegant and a little bit more sportier that the previous model. SIM card is available with 3G support for internet connection and phone calls/SMS. The AGPS support is there for when you go out for jogging to track your route or simply guide you when driving. Add to this the pedometer, heart rate monitor, calorie counter and IP65 certification and you get the most complete smartwatch at an affordable price compared to other similar or inferior products.
    Below you can see a video presentation of the No.1 D5+
