Two latest Google devices Nexus 5X and Nexus 6P are now supporting the USB Type-C though the latest Samsung Galaxy S7 and S7edge are only capable of supporting microUSB.
This has not only confused most of the Easyacc 30W 2-Port Wall Charger users but is even more annoying to learn that no one is able to agree on the charging standard to use. This has made most of the Easyacc 30W 2-Port Wall Charger users like me and you suffer. The complications witnessed when using the cables and the Type-C chargers are even more confusing. Using incompatible chargers and cables risk frying your devices.
However, you need not to worry since the latest Easyacc 30W 2-Port Wall Charger has simplified the matters. The last time I took some of my time to go through the variety of chargers in the market, I found the Easyacc 30W 2-Port Wall Charger to be only charger I can use until a universal standard is set.
The Easyacc 30W 2-Port Wall Charger is Reliable and Safe
By using durable materials which have been certified by the RoHS and the CE, the Easyacc 30W 2-Port Wall Charger has undergone immense testing to ensure it can last for a longer period of time. You device together with the charger will be well protected thanks to its multi circuit protection system.
The Easyacc 30W 2-Port Wall Charger Uses a Smart Universal Charge
Apart from the new faster charging models, the Easyacc 30W 2-Port Wall Charger has adopted a cutting edge Smart Charge technology which is able to offer faster charge to the USB devices just as the original chargers do.
The Easyacc 30W 2-Port Wall Charger Adopts Words Fastest Qualcomm charging technology
The quick charge port has offered the Easyacc 30W 2-Port Wall Charger up to four times faster charge compared to the conventional chargers.
