If you’re trying to find the larger screen smartphone, with full HD screen display and powerfull specs and faster processor, it’s seem the Newman Edge K2 Android smartphone is your perfect choice.
The new smartphone coming from Newman through the Newman Edge K2 Android smartphone that packs with 5.5 inch screen size, while the screen resolution is 1920 x 1080 pixel resolution, this machine is powered by quad-core MT6589TÂ processor, Interestingly, this phone is offers just only 899 yuan or translate to $146.84 USD price.
The Newman Edge K2 is sports with 1GB of RAM and 16GB of storage space but support for microSD card slot up to 32GB, running Android 4.2 Jelly Bean operating system with intelligent control system. In the camera, the machine has 5 megapixels front-facing camera and 13 megapixel rear-facing camera, including LED flash light. Meanwhile Newman Edge K2 is also supports for WCDMA + GSM dual sim dual standby, and has 3000 mAh battery capacity.
Here are the picture of Newman Edge K2 Android smartphone:
[via zol.com.cn]
