Stuck with a GT-8750 Android 4.1.1 cannot find Developer options settings.
Android 4.2 trick does not work (mutltiple clicks on either Model or Base band (no built version shows) )
Need help need to set to install to mem card have ADK and adb.exe but cannot switch one developer options since no show
Werner
[hr]
Werner
OK found it finally, was in applications settings, not in system!!!
