The MXIII-G TV Box is an updated version of this device. It has a Amlogic S812 Quad Core processor with the Octa Core ARM Mali-450 graphics engine. The 2GB of RAM are more than sufficient for most tasks. The only downside is the 8GB of internal storage, however it does take a SD Card so you can increase it’s storage. It performs very well for it’s price range.
The exterior looks quite appealing and it makes a good addition to any TV. There is an HDMI output, 2 USB ports, on OTG port, Optical audio, AV Port and an Ethernet port. It does have wifi and Bluetooth as well.
On the front of the box there is an power on,power off button, that has an LED that turns red or blue.
This box is running Android 5.1.1 and it does run very smooth while watching any movies or doing any task. It comes pre-installed with Netflix, Youtube, Kodi, MX Player and the Play Store.
The one thing i don’t like about it is the remote. This box is much easier to use with a mouse. Trying to use the remote is very difficult and makes everything take way too long.
Overall a very decent TV Box for around $63USD.
Review:
[video=youtube]https://www.youtube.com/watch?v=zmKn2dwSFxQ[/video]
